Proof using the Axioms, Analysis
The discussion revolves around proving statements using the axioms of real numbers, specifically focusing on inequalities and the existence of numbers. The original poster expresses difficulty in applying axioms to formal proofs, contrasting their previous experiences with different proof techniques.
  • Participants discuss the validity of the statements and the application of axioms, with some suggesting to focus on understanding the truth of the statements before formalizing proofs. Others propose breaking down the problems into manageable parts and using examples to explore reasoning.
Some participants have provided guidance on how to approach the problems, suggesting that the original poster concentrate on one problem at a time and consider the implications of the inequalities. There is an ongoing exploration of how to apply axioms and theorems correctly, with no clear consensus yet on the best approach.
The original poster is working under the constraints of a homework assignment that requires proofs based solely on axioms, which they find challenging due to their prior experience with different proof methods. There is also a mention of needing to understand the properties of numbers and inequalities in a more foundational way.
rbpl
1) For any x > 0 and 0 ≤ h < 1 we have (x + h)^2 ≤ x^2 + h(2x + 1).
2) For any x > 0 and p > 0 with x^2 < p there exists y > x with y^2 < p.
Prove the following statements (only using the axioms for the real numbers). At each step say which axiom you use.
The problems is that my professor expects everyone to know how to do this from previous class; however my former professor never explained anything like this.
I don't want an answer but I am hoping someone could guide me through proving this.
So, could anyone help me get started, I really have no idea where to begin.
What exactly are you having trouble with? Understanding why the statements are true? Or trying to translate an argument into a formal one? Or something else?
For the first one, the key is that if 0 ≤ h < 1, h2 < h.
For the second one, draw a number line with x, y, and p on it.
I suppose I am having trouble with both, in my previous class "Introduction to Mathematical Reasoning" I have never proved anything using axioms, most of the "proving" done in class was by induction and contradiction.
I know what the axioms are but I don't know how to apply them, in this case I have no idea where to begin.
Then worry about "why are they true" first.
These are elementary arithmetic statements. Forget about axioms and issues of formal proof for a moment -- just do arithmetic, and argue why these should be true statements.
I think I should concentrate on one problem at a time.
So:
x^2 + 2hx +h^2 ≤ x^2 + 2hx +h^2
h^2 ≤ h
or by example, Let x=1, h=0
(1 + 0)^2 ≤ 1^2 + 0(2(1) + 1)
1 = 1
or, Let x=1, h=0.5
(1 + 0.5)^2 ≤ 1^2 + 0.5(2(1) + 1)
2.25 < 2.5
Therefore, h^2 ≤ h is true.
Where would I go from here?
P.S. I did not expect such a quick response, thanks a lot.
So:
h^2 ≤ h
Given that 0 ≤ h < 1, h2 < h, so
(x + h)2 = x2 + 2xh + h2
< x2 + 2xh + h = x2 + h(2x + 1) QED
1 = 1
or, Let x=1, h=0.5
2.25 < 2.5
You can omit the examples above. No amount of examples can prove anything.
You weren't required to prove the statement above, but you need to use it to prove what you need to prove.
a) Since 0 ≤ h < 1 it follows that h^2 ≤ h (I think there is an axiom but I am not sure which one)
h^2 ≤ h
b) From this it follows that
(x+h)^2
= (x+h)(x+h)
= x(x+h) + h(x+h)
= x^2 + xh + hx + h^2
= x^2 + 2hx + h^2 ≤ x^2 + 2hx + h
= x^2 + h(2x+1)
Where the first equality is the definition of ^2, the second and third
equalities come from "the law of compatibility with multiplication", the forth from "the associative law of addition",the fifth inequality by (a), the sixth from
"the associative law of multiplication"
How is this? Am I using the right axioms?
h^2 ≤ h
I'm not sure the properties you are expected to use are truly axioms, so much as axioms and theorems. In this case (a < b, c > 0 -> ac < bc) is the Multiplicative Property of Inequality. If your instructor is expecting you to fabricate these proofs from basic principles you'll need to look up the derivations of the theorems.
Regardless, you do not need anything after the first line here.
(x+h)^2
= (x+h)(x+h)
= x(x+h) + h(x+h)
= x^2 + 2hx + h^2
≤ x^2 + 2hx + h
= x^2 + h(2x+1)
I made a minor edit to your statement so that each line has a separate comparison. The steps of your proof look sound but the rules you state are slightly off. Numbering the comparisons in order (equality and inequality) 1 through 6:
(1) Definition of second power (as you correctly stated)
(2) Distributive Property: a(b + c) = ab + ac
(3) Distributive again
(4) Additive Commutativity and "Combining Like Terms" (which is related to Distribution).
(5) From (a) (you are correct here)
(6) Factoring (again related to Distribution).
Associativity of Multiplication is a(bc) = (ab)c. For addition it is a + (b + c) = (a + b) + c. Neither occur here. I have not heard of the "law of compatibility with multiplication." Do you mind sharing it? I might know it by another name.
Just so you know, I have found that it is more important to be able to use the properties to form a valid proof, than it is to know all the names of the steps, although knowing them can't hurt.
--Elucidus
Thanks a lot for your help guys. As far as the other one
"For any x > 0 and p > 0 with x^2 < p there exists y > x with y^2 < p."
Mark44 said to draw a number line which I did. When x=1, x^2=1, y=2, y^2=4, then y^2>x^2, p=6 then p>y^2. So I see how this makes sense. but unlike the first example I am not sure what is it I need to concentrate on. Do I need to brake down the y^2 < p and work with that (kind of like the first one).
I finally figured out what your professor is doing. I think she has a very beautiful goal in mind. You are going to prove directly from first principles that the set
{w : w^2 < p}
has no largest member.
You have part (1) done. To prove part (2), you will use part (1). Hint: given x^2 < p, can you somehow find an h (between 0 and 1) such that x^2 + h*(2x+1) < p?
Can I ask what would make you think that my teacher is trying to do that (I just wish I could see that myself). Also am I looking for a sample number just to see if it works and then by the first equation I should prove that x^2=(x+h)^2?
Don't limit yourself to integers, as you seem to be doing.
Put x^2 on the number line to the left of a number p. Do you see that you can squeeze in a number between x^2 and p?
Yes, and if we keep the number constant so they stay in the same spots on number line then we could always squeez in another number between them that would be the principle of density where x<((x+z)/2)<z<((y+z)/2)<y and so on.
Does this have anythine to do with what I am trying to prove?
If x and p are given, can't you solve x^2 + h*(2x+1) < p for h?
  • · Replies 19 ·
