Thermal Expansion - Pendulum of a Grandfather Clock
The discussion revolves around the thermal expansion of a brass pendulum in a grandfather clock, specifically how changes in temperature affect the pendulum's timekeeping. The original poster is tasked with determining the time gained or lost when the clock is kept at a higher temperature than its calibrated setting.
  • Participants explore the relationship between the pendulum's length and its period, questioning how temperature changes affect these variables. There is discussion about the use of equations related to pendulum motion and thermal expansion, with some participants expressing confusion about the underlying concepts and calculations.
Several participants have provided hints and guidance, particularly regarding the application of the binomial expansion and the relationship between the original and new periods of the pendulum. There is an ongoing exploration of the mathematical expressions involved, with some participants making progress while others seek clarification on specific steps.
Participants note the importance of the coefficient of linear expansion and the temperature difference in their calculations. There is also mention of assumptions regarding the pendulum's length and period at specific temperatures, which are critical to the problem's setup.
dmullin4
Thermal Expansion -- Pendulum of a Grandfather Clock
The pendulum in a grandfather clock is made of brass (coefficient of linear expansion = 19 x 10^-6) and keeps perfect time at 17 degrees Celsius. How much time is gained or lost in a year if the clock is kept at 28 degrees Celsius? (Assume the frequency dependence on length for a simply pendulum applies.)
T = 2pi * sqrt(L/g)
delta L = alpha*L(naught)*delta T
L = L(naught)*(1 + alpha*delta T)
I really don't know where to even start with this. Once given a push in the right direction, I should be ok. But I just don't get the relationship.
Welcome to Physics Forums.
HINT: What is the length of the pendulum if it keeps perfect time?
I'm not sure. Wouldn't it depend on the gravity at a certain location? The instructor posted a worksheet that compares the T = 2pi * sqrt(L/g) initial to the final. But the comparisons he made are foreign to me. He has the fractional loss given by delta T/T(naught). Then he does a lot of substitutions and simplifications that I don't completely follow.
Okay, let's start by finding the ratio T/T0 then.
Ok, so I have T0 = 2pi * sqrt(L0/g) at 17o C and T = 2pi * sqrt(L/g) at 28o Celsius. T is greater than T0 because L is greater than L0. I understand this part. But then they have the clock is losing time by an amount of delta T = T-T0. Where does that come from?
Good. Now, the next step is to find the fractional change in period, as your instructor did. So can you write down
[tex]\frac{T}{T_0} = \ldots[/tex]
T/T0 = 2pi * sqrt(L/g) / 2pi * sqrt(L0/g)
= sqrt(L/g) / sqrt(L0/g)
= sqrt(L) / sqrt(L0)
Now I'm lost again.
Now I'm lost again.
[tex]\frac{T}{To}[/tex] = sqrt( Lo + Lo*α*t)/sqrt(Lo)
Length Lo of the grandfather clock is 1 m and its period is 2 s.
Since [tex]\alpha[/tex] is very small, by using binomial expansion, the equation can be rewritten as
[tex]\frac{T}{To}[/tex] = 1 + 1/2*α*t, where t is the temperature difference and α is the coefficient of linear expansion.
[tex]\frac{T}{To}[/tex] - 1 = 1/2*α*t
[tex]\frac{T - To}{To}[/tex] = 1/2*α*t
(T - To)/To = 1/2*α*t = the chage in then period per second.
(T - To) is the change in one oscillation, i.e. in 2 seconds.
( T - To )/To* number of seconds in one year gives you the required result.
Where do you get the information that T = sqrt(L0 + L0*a*t) ?
Okay, I'll walk through it slowly. We start from your first line,
[tex]\frac{T}{T_0} = \frac{2\pi\sqrt{L/g}}{2\pi\sqrt{L_0/g}}[/tex]
Notice that the factors of 2 pi cancel and we can combine the square root.
[tex]\frac{T}{T_0} = \sqrt{\frac{L}{g}\frac{g}{L_0}}[/tex]
The factors of g cancel yielding
[tex]\frac{T}{T_0} = \sqrt{\frac{L}{L_0}}[/tex]
You with me so far?
The next step is to insert the expression for L in terms of L0, T and a into the expression. Do you follow?
Yes, I got that far. So now we use L = L0(1 + alpha * delta T) ?
sqrt(L0(1 + alpha * delta T)/L0) = sqrt(1 + alpha * delta T)
alpha = 19 x 10-6
delta T = 28 - 17 = 11
sqrt(1 + (19 x 10-6 * 11)) = sqrt(1 + 2.09 x 10-4)
sqrt(1.000209) = 1.0001044...
So is this number right? If so, now what?
Try re-reading rl.bhat's post, paying particular attention to the binomial expansion part.
OK, I got the part where sqrt(L0(1 + alpha * delta T)/L0) would equal sqrt((L0 + L0* alpha * delta T)/T0).
What I don't understand is where the 1/2 comes from. Does it have something to do with the original length being 1m and the original period equalling 2s?
If x is very small ( 1 + x )^1/2 can be written as 1 + 1/2*x, by neglecting the higher powers of x in the binomial expansion.
I THINK I GOT IT!
Ok,
Original Period = 2pi*sqrt(L0/g) at 17 Celsius
New Period = 2pi*sqrt(L/g) at 28 Celsius
delta T/T0 = T-T0/T0 = (T/T0)-1
[2pi*sqrt(L0/g) / 2pi*sqrt(L/g)] -1 = sqrt(L/L0) -1 = sqrt(L0(1+alpha*delta temperature)/L0) -1
sqrt(1 + alpha*delta temperature) - 1 = sqrt(1 + 19*10^-6*11) - 1 = 1.044*10^-4
1.044*10^-4 * 31536000s = 3295.339s = 54.9 minutes!
My only question now is: Where did I pull "delta T/T0" from? I saw it on another website and used it to get the right answer, but I don't understand how it fits. I know that since its getting heated, the pendulum will expand, making L > L0 and thus T > T0. Am I missing something elementary? I feel like I'm looking over the obvious.
Thanks for everyone help.
Check this calculation.
That caculation checks out. Let me try to type it better.
{sqrt[1+(19*10^-6)*11]} - 1 = sqrt(1.000209) - 1 = 0.0001044 = 1.044*10^-4
OK. That is correct.
  • · Replies 17 ·
10K
