Vector Statics question, hanging pipe
The discussion centers on calculating the forces at five hangers supporting a 31 ft steel pipe weighing 81 lbs. The hangers are positioned at 1, 5, 18, 22, and 30 ft from one end of the pipe. The challenge lies in the limited static equilibrium equations available, as there are five unknown forces and only two equations. The suggested approach is to use an approximate method to estimate the forces on each hanger rather than relying solely on algebraic solutions.
  • Understanding of static equilibrium equations in physics
  • Familiarity with moment calculations in mechanics
  • Knowledge of approximate methods for force estimation
  • Basic principles of structural analysis
  • Study the method of moments in static equilibrium problems
  • Research approximate methods for force distribution in structures
  • Explore examples of similar problems involving multiple supports
  • Learn about the principles of load distribution in beams and pipes
Students in engineering or physics courses, particularly those focusing on mechanics and statics, as well as professionals involved in structural analysis and design.
cpmustang
My question is about the method used for calculation.
The problem reads:
There is a steel pipe of uniform size and density at a length of 31 ft. It's weight is 81 lbs. It is hung from a concrete deck with five concrete hangers. Measuring from one end of the pipe, the hangers are located at 1, 5, 18, 22, and 30 ft.
Calculate the force at each hanger.
I immediately want to start making formulas for the moments at each hanger location, but then there is a ton of algebra. Is there a simple method to do this?
That is an admirable way of thinking, and is a good approach to use whenever possible. However, in the given problem, you have five unknowns, but only two static equilibrium equations, right? Hint: Do you think they might want you to use an approximate method to estimate the approximate force on each hanger?
33K
  • · Replies 35 ·
27K
10K
