Why Does the Same Current Flow Through Every Segment of a Wire?
  • Thread starter Thread starter deepankvora
    Doubt Electricity
The discussion clarifies that the current 'i' flowing through a wire remains constant across all segments, as established by fundamental principles of electric current. The user initially questioned why a small element of the wire, denoted as 'dl', should also have the same current 'i' instead of a different value 'di'. The explanation provided emphasizes that current is defined as the rate of charge flow, i = dQ/dt, which does not vary with the length of the wire segment. Additionally, any variation in current would lead to charge accumulation, contradicting Kirchhoff's junction rule.
  • Understanding of electric current and its definition
  • Familiarity with Kirchhoff's junction rule
  • Basic knowledge of Biot-Savart Law
  • Concept of charge flow in conductors
  • Study the implications of Kirchhoff's laws in circuit analysis
  • Explore the Biot-Savart Law in detail for magnetic field calculations
  • Learn about charge conservation in electrical circuits
  • Investigate the relationship between current, voltage, and resistance in Ohm's Law
Students studying electrical engineering, physics enthusiasts, and anyone seeking to understand the principles of electric current and circuit behavior.
deepankvora
Curent Electricity Doubt! PLEASE HELP!
I did not understand one thing.. If it is given that a wire has a current 'i', then why do we say (in applications of laws such as biot savart law) that the current in a small element of the wire is also 'i', that is the same current that passes through the whole conductor.
can someone explain this. i got really confused on this one.
I thought we should take current in the ' dl ' element of the wire as ' di ' and not i. I am wrong. Please Explain, anyone!
Current is [tex]\frac{dQ}{dt}[/tex], the amount of charge which passes through a cross-section of the wire per unit time. This value does not depend on the length segment of wire.
Also, for one segment of wire to have a different current than another causes a buildup of charge, inconsistent with Kirchhoff's junction rule.
