What Is the Best Low-Cost Material for Generator Windings?
The discussion revolves around the materials used for generator windings, specifically focusing on low-cost options and the insulation properties of these materials. Participants explore the types of wire suitable for generator coils and the implications of insulation on electrical conductivity.
  • One participant inquires about the best low-cost material for generator windings and whether the same wire used in electrical motors can be utilized.
  • Another participant asserts that copper wire with enamel insulation is commonly used for both motors and generators, claiming it to be the best and cheapest option.
  • A request for clarification on enamel insulation is made, specifically regarding its role in preventing current flow between turns of winding.
  • It is noted that while enamel is common, there are various insulation types available that depend on factors like operating temperature and mechanical toughness, including plastic films such as Kapton and Formvar.
  • Participants discuss the importance of insulation in preventing "shorted turns," which could lead to excessive current flow and potential damage to the wire or malfunction of the generator.
Participants generally agree on the use of copper wire for generator windings and the necessity of insulation, but there is no consensus on the best specific material or insulation type, as various options are mentioned.
The discussion highlights the variability in insulation materials and their properties, but does not resolve which specific type is optimal for all applications.
neduet
Hello friends
friends, which material generator coil is made and are they insulated of current but not magnat flux or can we use same wire which is used in electrical motors winding,
Q:which is low cost and best material winding for generator?
thanx
Motors and generators both use the same sort of wire. It is copper wire with enamel insulation.
This is also the best and cheapest wire to use
The insulation is used so that the wires can touch in the winding, but no electric current can flow between the wires.
some explanation please about enamel insulation
is this stooping current to flow one round (one turn) of winding to other one.
Yes. It's not always (in fact these days, it's hardly ever) enamel. There are several types depending on operating temperature, corrosion resistance or mechanical toughness desired but most are some type of plastic film, like Kapton or some other polyimide, Formvar (a polyvinyl resin), nylon, polyester and various combinations of these.
Yes, the function is to stop wires which have to touch physically (because they are tightly wound into a coil) from conducting electricity between them.
If this did happen, this would be called a "shorted turn" and it would cause a large current to flow in this turn and possibly make it melt the wire.
It would also cause the motor or generator to work badly or not at all.
Thanks for that, negitron. I had no idea.
  • · Replies 74 ·
11K
