Is work done against friction always negative?
The discussion centers on the concept of work done against friction in physics. It clarifies that while friction opposes motion, the work done can be calculated using the formula W = F * cos(θ) * d, where θ is the angle between the force and displacement. When friction is present, the total work done is expressed as the change in kinetic energy plus the work done against friction. The confusion arises from the interpretation of the angle in the work formula, particularly when considering the direction of forces and displacement.
  • Understanding of Newton's laws of motion
  • Familiarity with the work-energy theorem
  • Basic knowledge of vector components in physics
  • Concept of kinetic energy and its relation to work
  • Study the work-energy theorem in detail
  • Learn about vector components and their application in physics
  • Explore the effects of friction on motion using simulations
  • Review examples of work done in various physical scenarios
Students studying physics, educators teaching mechanics, and anyone seeking to understand the principles of work and energy in the presence of friction.
jongro
Since friction is in the opposite direction as the direction of movement, wouldn't you expect the work to be negative? When I put it in the work formula, W = F * cos(180O) * d
it comes out positive because F is negative and cos(180) is negative too.
This means that if I have another force pulling something across a surface, then it would do more work if there is friction.
I read somewhere that the work is equal to the change in kinetic energy between two points but I was working on some homework and I realized that the only way I could get the right answer is if I made is so that W = F * cos(0O) * d (instead of theta = 180) in the friction work formula; that way friction gives negative work and when I add the two it equals to the change of kinetic friction.
Is there anything wrong in my original reasoning that W = F * cos(180O) * d?
I'm generally confused about work, could someone explain to me how it works?
in a case of no friction
total work done= change in kinetic energy
with friction
total work done= change in kinetic energy + work done against friction
or if you want
total work done= change in kinetic energy - work done by frictional force
If the kinetic energy of the body increases, the work is done on the body. If the kinetic energy decreases, the work is done by the body.
So you have to decide the direction of the net force and the displacement before using the formula.
  • · Replies 16 ·
  • · Replies 38 ·
