Continuity of the identity function on function spaces.
The identity functions id:C^{0}_{1}[a,b] to C^{0}_{p}[a,b] and id:C^{0}_{p}[a,b] to C^{0}_{\infty}[a,b] are proven to be discontinuous for p in the range (1, ∞). The discussion highlights the necessity to demonstrate that the p-norm and the ∞-norm (or 1-norm) are not equivalent. A sequence of functions, such as f_n(x)=exp(x/n), is suggested for proving the discontinuity of the identity function from C^{0}_{p}[0,1] to C^{0}_{\infty}[0,1]. The proof relies on establishing that for any ε>0, there exists a δ>0 such that the conditions of the norms are violated.
  • Understanding of normed vector spaces, specifically C^{0}_{p}[a,b] and C^{0}_{\infty}[a,b]
  • Familiarity with p-norms and ∞-norms in functional analysis
  • Knowledge of continuity and discontinuity in the context of functions
  • Ability to work with sequences of functions and their properties
  • Study the properties of p-norms and their implications in functional analysis
  • Learn about the equivalence of norms in vector spaces
  • Explore examples of discontinuous functions in normed spaces
  • Investigate the role of sequences in proving properties of function spaces
Mathematicians, students of functional analysis, and anyone studying continuity properties of functions in normed spaces will benefit from this discussion.
ELESSAR TELKONT
Show that if [tex]p\in (1,\infty)[/tex] the identity functions [tex]id:C^{0}_{1}[a,b]\longrightarrow C^{0}_{p}[a,b][/tex] and [tex]id:C^{0}_{p}[a,b]\longrightarrow C^{0}_{\infty}[a,b][/tex] are not continuous.
[tex]C^{0}_{p}[a,b][/tex] is the space of continuous functions on the [a,b] with the p-norm [tex]\left\vert\left\vert f\right\vert\right\vert_{p}=\int_{a}^{b}\vert f\vert^{p}\,dx[/tex]
It is sufficient to prove that for [tex]C^{0}[0,1][/tex] because I can map the interval [tex][0,1][/tex] to the interval [tex][a,b][/tex] via [tex]x=(b-a)t+a[/tex]. In fact, since [tex]C^{0}[0,1][/tex] is a vector space is sufficient to prove that for [tex]f_{0}\equiv 0[/tex] the identity is discontinuous.
To prove discontinuity I have to prove that [tex]\exists \epsilon>0 \mid \forall\delta>0[/tex] I can show that [tex]\left\vert\left\vert f\right\vert\right\vert_{1}<\delta \longrightarrow \left\vert\left\vert f\right\vert\right\vert_{p}>\epsilon[/tex] or what's the same, there is a sequence of functions that the area below their absolute value is less than delta but the area below their absolute value elevated to p is not bounded by epsilon. For the second case I must prove that there exists a sequence of functions for that the maximum of each is not bounded by epsilon but the area below their absolute value elevated to p is bounded by delta.
In other words I have to prove that the [tex]p[/tex]-norm and the [tex]\infty[/tex]-norm (or the [tex]1[/tex]-norm) are not equivalent.
My problem is that to prove vía sequences I can't figure out a function sequence that elevated to p can help me to prove that.
I have already proven something similar: that [tex]id:C^{0}_{1}[0,1]\longrightarrow C^{0}_{\infty}[0,1][/tex] is not continuous. I have done it via the functions [tex]g_{\delta}(x)=1-\frac{1}{\delta}x[/tex] for [tex]0\leq x\leq \delta[/tex] and 0 for [tex]\delta\leq x\leq 1[/tex] and it's straightforward. However this functions don't help me in my present problem. Please Help!
Try [tex]f_n(x)=\exp{(x/n)}[/tex].
Btw, I'm sure you just forgot to put this in, but the p-norm is
[tex]\|f\|_p = \left(\int_a^b |f|^p\,dx\right)^{1/p}.[/tex]​
  • · Replies 40 ·
  • · Replies 28 ·
