Speed, Velocity and Average Acceleration
The discussion revolves around a physics problem involving an automobile making a turn while maintaining constant speed. The problem requires participants to analyze speed, velocity, and average acceleration as the car transitions from traveling north to east over a quarter-circle arc with a radius of 9.3 m.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the relationship between distance, speed, and time, questioning the correct distance traveled during the turn. There are attempts to clarify the calculation of the distance for a quarter-circle and how to express initial and final velocities as vectors. Some participants express confusion about the initial velocity and how to represent it in vector notation.
The discussion is ongoing, with participants providing guidance on calculating distance and speed, as well as how to express velocities as vectors. There is a mix of interpretations regarding the initial velocity, with some participants attempting to clarify the concepts while others express confusion about the physics involved.
Participants note that the problem does not explicitly provide the circumference of the circle, leading to some uncertainty in calculations. There is also a mention of the need for a foundational understanding of vectors to tackle the problem effectively.
slu1986
1. At t = 0, an automobile traveling north begins to make a turn. It follows one-quarter of the arc of a circle of radius 9.3 m until, at t = 1.60 s, it is traveling east. The car does not alter its speed during the turn.
(a) Find the car's speed.
(b) Find the change in its velocity during the turn.
(c) Find its average acceleration during the turn.
2. speed = distance traveled/time traveled
change in velocity = vf - vi
average acceleration = change in velocity/change in time
3. I am a little confused at how to begin solving this problem. I know that the first vector going north is going to be the initial velocity = vi and the second vector is going to be the final velocity = vf. the initial time = 0 sec and the finald time is = 1.60 s. Distance traveled is = 9.3 m. I am so lost at where to start. Can someone please guide me in the right direction to solving this problem?
Since the car is traveling at constant speed, it covers equal distances in equal times, so distance traveled is speed multiplied by time. You know that the time for a quarter-turn is 1.60 s. What is the distance traveled? It is not 9.3 m, it is one-quarter of a circle of radius 9.3 m. This should get you started.
So would the distance traveled in 1.60 s be 9.3 m -0.25 = 9.05 m
would speed be = 9.05 m/1.60 s = 5.65 m/s
What is the circumference of the circle? One-quarter of that is what you are looking for.
kuruman said:
What is he circumference of the circle? One-quarter of that is what you are looking for.
I have no idea what the circumference of the circle is..It doesn't state that in the problem. It only gives the radius of the circle of 9.3 m
It is something you are supposed to know. Please memorize this formula. It is extremely handy when doing physics. The circumference of a circle is
C = 2 π r
where r is the radius.
C = 2 pi r = 2 * 3.14 * 9.3 m = 58.4 m
58.4 m - 0.25 = 58.15 m
to get speed would it be = 58.15 m/ 1.60 s = 36.3 m/s
If you are jogging on a circular track such that one lap is 58.4 m, what is one-quarter of the way around the track? It is certainly not 58.15 m because that is almost a complete lap.
Would it be 58.4 m * 0.25 = 14.6 m
speed = 14.6 m/1.60 s = 9.12 m/s
That would be correct. Now for part (b), you need to write the initial and final velocities as vectors in unit vector notation. The change in velocity is the difference taken as Final velocity minus Initial velocity. I assume you know how to subtract vectors.
So would the change in velocity be = 9.12 m/s - 0 m/s = 9.12 m/s because the initial velocity is 0 m/s?
The car is initially moving north. Its velocity is not zero. How would you write the initial velocity as a vector?
So to find the initial velocity would you take 9.3 m^2 + 9.3 m^2 = 172.98 m and take the sqr rt = 13.2 m
to get velocity = 13.2 m/1.60 s = 8.22 m/s <---initial velocity?
This problem is in two dimensions. Any 2-D vector A can be written in unit vector notation as
[tex]\vec{A}=(something) \hat{i} + (something \ else)\hat{j}[/tex]
What must you put in the above expression for "something" (or x-component) and "something else" (or y-component) to get the initial velocity? Assume that "North" is +y and "East" is +x.
would you use 9.12 m/s and plug that into the pythagorean theorum to get the initial velocity. 9.12 m/s^2 + 9.12 m/s^2 = 166.35 m/s and take sqr root = 12.9 m/s
The Pythagorean Theorem is no help here. If a car is moving North at a speed of 9.12 m/s, what is the northward component of the velocity vector and what is the eastward component of the velocity vector? You need to supply two numbers.
Northward =
Eastward =
Northward =
Eastward =
I am so lost..I do not understand what you're saying. The only number I can come up with is 9.3 m / 1.60 s = 5.81 m/s. I don't know what other number it could possibly be?
We have already established that the speed is
so no more division is necessary. Let me ask you this. Do you understand vectors? Have you studied them? You need to have some understanding of vectors before you can tackle this problem. I will give you part of the answer, but you have to make an effort to understand vectors.
The initial velocity of the car is given by
[tex]\vec{v}_{initial}=0\ \hat{i}+9.12\ \hat{j}[/tex]
The above expression says that initially, the car is moving with 0 m/s in the eastward direction and 9.12 m/s in the northward direction. In other words, the car is moving due north at 9.12 m/s.
Now can you write the final velocity vector in a similar fashion?
Yes, I have studied vectors before in Biomechanics..I understand them, I just get confused by physics in general. So you're saying that initial velocity is 0 m/s. So the change in velocity would be 9.12 m/s?
I never said that the initial velocity is zero. Look at the equation I gave you. Does it say
[tex]\vec{v}_{initial}=0 \ ?[/tex]
No. What does it say instead? Hint: I told you what is says in my previous posting.
Ok..so the initial velocity is the same as the final velocity 9.12 m/s?
If the initial and final velocities are the same, then there is no change to the velocity and the car will be moving in the same direction with the same speed. Is that what's happening here? No. The car has changed direction. Speed and velocity are not two different names for the same thing. Velocity is a vector, it has magnitude and direction. Speed is the magnitude of the velocity vector and has no direction. In this example the velocity of the car changes but not its speed.
You say you understand vectors. What is the motion of the car after completing the turn? It is moving due east at 9.12 m/s. Express the final velocity of the car with a vector equation using the same technique I used to express the initial velocity.
I am sorry, but I am very confused now. final velocity = 9.12 m/s = 0 m/s.
Please read posting #14. It provides a template for writing any vector. Then look at Posting #18. It shows how to apply this template to write the initial velocity vector. Can you follow the template and come up with an expression for the final velocity? To do this you need to figure out the eastward and northward components of the final velocity vector. What are they?
Eastward component = 9.12 m/s
Northward component = 0 m/s
Excellent. So in the template if the "something" multiplying the i-hat is the eastward component and the "something else" multiplying the j-hat is the northward component, how would you write the final velocity vector in a manner similar to the initial velocity vector?
final velocity = 9.12 m/s + 0 m/s
More correctly
[tex]\vec{v}_{final}=9.12 (m/s) \hat{i}+0 (m/s) \hat{j}[/tex]
The i-hat and j-hat are important to help keep track of the components. Now take the difference
[tex]\vec{v}_{final} - \vec{v}_{initial}[/tex]
keeping all the i-hats together and all the j-hats together and you're done. You have found the change in velocity.
kuruman said:
More correctly
So the change in velocity is 0 m/s?
How do you calculate the average acceleration during the turn?
How do you get 0 m/s? Show your work. I explained to you in posting #26 that the change in velocity cannot be zero because the velocity changes its direction.
