Force on a charge at the center of a non-uniform charge density cylinder
The discussion focuses on calculating the force on a charge Q located at the center of a non-uniformly charged cylinder with a volume charge density described by P + P0 + Bz, where P0 and B are constants. The user correctly identifies the need to compute the electric field generated by the cylinder before determining the force. The integration process involves evaluating the electric field contributions from differential elements of the cylinder, leading to complex integrals that may require computational tools like Mathematica for evaluation.
  • Understanding of electric fields and forces in electrostatics
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of charge density concepts and their implications in physics
  • Experience with computational tools such as Mathematica for solving complex integrals
  • Learn advanced integration techniques for evaluating electric field contributions from continuous charge distributions
  • Study the principles of electrostatics, focusing on non-uniform charge distributions
  • Explore the use of Mathematica for symbolic integration and solving physics problems
  • Investigate the concept of electric potential and its relationship to electric fields and forces
Students and professionals in physics, particularly those studying electromagnetism, as well as educators looking for practical examples of integrating charge distributions in electrostatics.
mjordan2nd
Consider a cylinder, radius R and length L. Suppose the cylinder is charged with a volume charge given by P+P0 + Bz, where p0 and B are constants. Find the force on a charge Q at the center of the cylinder.
E=q/4*pi*e*r^2
I first found the electric field contribution of a disk with uniform charge density on a point z above the center of the disk, where e is epsilon-not and o is the charge density on the disk.
[tex]\int \frac{z r o 2 \pi }{4 \pi e \left(r^2+z^2\right)^{3/2}} \, dr[/tex]
The indefinite integral gave me
[tex]-\frac{o z}{2 e \sqrt{r^2+z^2}}[/tex]
Evaluating from 0 to R gave me
(oz/2e)*(1/z-(z^2+r^2)^-1)
I then used this to evaluate the integral from -z/2 to z/2 on the cylinder, and came up with this expression:
[tex]\int_{-\frac{L}{2}}^{\frac{L}{2}} \left(\left(\frac{L}{2}+z\right) b+p\right) z \left(\frac{1}{z}-\frac{1}{\sqrt{r^2+z^2}}\right) \, dz[/tex]
I have two questions:
Have I gone about this problem correctly so far, and how do I proceed from here. I don't know how to evaluate the integral. I figured I'd calculate the E-field first and then the force.
Thanks for any help...
Plugging this into mathematica gives
[tex]\text{If}\left[\text{Im}\left[\frac{r}{L}\right]\geq \frac{1}{2}\left\|\text{Im}\left[\frac{r}{L}\right]\leq -\frac{1}{2}\right\|\text{Re}\left[\frac{r}{L}\right]\neq 0,\frac{-2 b L^3-8 b L r^2+4 b L^2 \sqrt{L^2+4 r^2}+8 L p \sqrt{L^2+4 r^2}-4 b r^2 \sqrt{L^2+4 r^2} \text{Log}[2]+b r^2 \sqrt{L^2+4 r^2} \text{Log}[16]-4 b r^2 \sqrt{L^2+4 r^2} \text{Log}\left[-L+\sqrt{L^2+4 r^2}\right]+4 b r^2 \sqrt{L^2+4 r^2} \text{Log}\left[L+\sqrt{L^2+4 r^2}\right]}{8 \sqrt{L^2+4 r^2}},\text{Integrate}\left[\left(b \left(\frac{L}{2}+z\right)+p\right) \left(1-\frac{z}{\sqrt{z^2+r^2}}\right),\left\{z,-\frac{L}{2},\frac{L}{2}\right\},\text{Assumptions}\to !\left(\text{Im}\left[\frac{r}{L}\right]\geq \frac{1}{2}\left\|\text{Im}\left[\frac{r}{L}\right]\leq -\frac{1}{2}\right\|\text{Re}\left[\frac{r}{L}\right]\neq 0\right)\right]\right][/tex]
The indefinite integral gives [tex](-(2 p + b (L + z)) (r^2 + z (z - Sqrt[r^2 + z^2])) + <br /> b r^2 Sqrt[r^2 + z^2] Log[z + Sqrt[r^2 + z^2]])/(2 Sqrt[r^2 + z^2])[/tex]
I could evaluate the indefinite but I'm not sure if I've set the problem up correctly. Again, any help would be appreciated.
  • · Replies 19 ·
  • · Replies 16 ·
