Why Can't You Cancel Out the Square Root and Square in a Square Root Problem?
The discussion revolves around the mathematical expression involving absolute values and square roots, specifically the relationship between |-4| and √((-4)²). Participants are exploring the implications of the square root function and absolute value in the context of real and complex numbers.
  • Conceptual clarification, Assumption checking, Mixed
  • Some participants attempt to clarify why |-4| does not equal √((-4)²), noting the distinction between absolute values and principal square roots. Others question the validity of certain interpretations and definitions related to square roots and absolute values.
The discussion is ongoing, with various interpretations being explored. Some participants provide insights into the properties of square roots and absolute values, while others express confusion or challenge certain statements. There is no clear consensus, but multiple perspectives are being shared.
Participants are addressing potential misunderstandings regarding the square root function's domain and the nature of absolute values. There are references to previous edits in the original post that may have influenced the discussion.
temaire
Can someone explain to me how [tex]|-4|= \sqrt{(-4)^{2}}[/tex]
I'm wondering why you can't cancel out the square root sign and the square above the -4, to leave you with -4.
I know this has something to do with the absolute value of -4, being 4, but I just don't completely understand why you can't cancel out the square root sign and the square.
|-4| ≠ √(-4²) (because |-4| = 4 and √(-4²) = √(-1(4²)) = √(-1(16)) = √(-16) = 4i, where i = √(-1) is the imaginary number). Therefore, trying to explain how |-4| = √(-4²) is meaningless.
It's not meaningless. In R, a square root cannot be a negative number, hence the absolute value sign.
Because |-4|=|[itex]\pm[/itex]4|=4. Why it is like that?
Because √(-4)2=√16=4 but also √42=√16=4.
You need to consider both positive and negative value for 4.
kbaumen, I suspect that the original poster had edited his/her post. Before he/she edited his/her post, it was √(-4²), and go to this http://hotmath.com/images/gt/lessons/genericalg1/parabola_width.gif" , and it's obvious that y > 0 for any x values that is x ≠ 0), and |-4| = 4.
By writing [tex]\sqrt{x} = r[/tex], it means that, r is the principal square root of x.
The principal square root of a non-negative number x is the number that satisfies the 2 following properties:
  • Firstly, it's a non-negative number, i.e r >= 0. (1)
  • And secondly, its square is x (i.e, it's one of the 2 square roots of x). (2)
For any positive real x (i.e x > 0), there are 2 distinct square roots of x:
  • The principal one: [itex]\sqrt{x} > 0[/itex]
  • And the other one: [itex]-\sqrt{x} < 0[/itex]
For x = 0, the 2 square roots becomes 1, which is: [tex]\sqrt{0} = 0[/tex]
For x < 0, there's no real square root of it. There exists complex ones, but just don't worry about it for now. :)
[tex]\sqrt{(-4) ^ 2} \neq -4[/tex] because -4 is negative, and hence cannot be the principal square root of (-4)2.
Using the 2 properties of the principle square root above, namely (1), and (2), we derive the following formula:
[tex]\sqrt{\alpha ^ 2} = |\alpha|[/tex].
Which can be easily proven. You can give it a try, if you want. :)
In that case I agree with you, but when I replied it was already [tex]\sqrt{(-4)^2}[/tex]. Perhaps I should've read your post more carefully.
njama said:
Because |-4|=[itex]\pm[/itex]4. Why it is like that?
|-4| [itex]\neq \pm 4[/itex]! The absolute value of a number has a single value that is always nonnegative!
This doesn't make any sense. For real numbers, the square root function's domain is nonnegative real numbers. The number 4 does not have a negative value.
Sorry about it I meant |-4|=|[itex]\pm 4[/itex]|=4. I will fix it immediately. :eek:
Comment:
[tex]\sqrt{(-4)^2} \neq \sqrt{-1(4^2)}[/tex]
The left side equals 4 while the right equals 4i (not 4). [itex](-4)^2 = (-1 \cdot 4)^2 = (-1)^2(4)^2 = (1)(16) = 16.[/itex]
In general
[tex]\sqrt{x^2} = \left| x \right|[/tex] as has been mentioned.
--Elucidus
In addition to Elucidus's comment, there is a factoring property for the square root (and other roots) that is often misused.
If a and b are nonnegative, then [itex]\sqrt{ab}~=~\sqrt{a}\sqrt{b}[/itex].
Elucidus said:
Comment:
In general
--Elucidus
Notice that he wrote
[tex]\sqrt{(-4^2)}[/tex]
instead of
Thou shalt not misquote.
instead of
Indeed, I mistook that quote. Apologies. The OP stated [tex]\sqrt{(-4)^2}[/tex] and I mistakingly thought jhooper3581 was citing that expression. He did not and I missed that.
--Elucidus
--Elucidus
So did I at first.
So would it be correct to say that although there is a positive and a negative square root to a number, we only consider the positive one since the square root is a function and functions can only have one y value for every x value?
No that is simply not correct. Consider y = x2. In fact, this is your problem.
Here is a illustration. I hope that after all those posts you will understand what these people are saying to you.
http://img225.imageshack.us/img225/42/graphofquadratic.png
[/URL]
Actually I believe I am correct, well at least to some degree. I think that you just misunderstood me. I said that since the square root is a function, you can only have one y value for each x value, thus we only consider the principal square root. What are you trying to show with your illustration?
Ok, if your function is [itex]y=\sqrt{x}[/itex], then there is unique value for y, by choosing different [itex]x \in [0, +\infty][/itex]. And do you know what makes the function with that property?
The function is neither odd nor even.
Well, what do you mean? Which function are you referring to? Of course the square root function is neither odd, nor even, because its domain is R+, which is clearly not symmetric to 0. But I'm wondering if it does have anything to do here??
As far as my knowledge goes, this is correct. :)
Thanks VeitDao, you've been a great help.
Here is why:
temaire said:
...you can only have one y value for each x value, thus we only consider the principal square root...
  • · Replies 21 ·
