Will this linear generator (NIB magnet) work to light infrared pulses?
The discussion revolves around the feasibility of using a linear generator, specifically one utilizing a neodymium iron boron (NIB) magnet, to power an infrared LED for a brief duration. Participants explore the mechanics of the generator, the design considerations, and the potential challenges involved in achieving the desired outcome.
  • One participant proposes using a linear generator to light an infrared LED for 1/30 of a second by creating a current when a switch is pressed, questioning the effectiveness of this approach.
  • Another participant suggests considering alternative methods, such as a one-shot or piezoelectric button, to achieve the same result more efficiently.
  • A different viewpoint indicates that the design must ensure the coil is only affected by one pole of the magnet, and expresses skepticism about whether the generated voltage would be sufficient to light the LED under load.
  • Further questions are raised regarding the specifics of the magnet's properties, including its magnetization, the number of coil turns, the surface gauss, and the resistance of the coil, emphasizing the importance of these factors in determining the output.
  • Participants inquire about the effects of varying parameters such as turns, gauss, coil area, and the speed of the magnetic field's movement on the generator's performance.
  • One participant humorously references Pythagoras in relation to the calculations needed for the project, indicating a need for mathematical considerations in the design.
  • There is a mention of the need for diodes to convert alternating current to direct current, highlighting additional technical challenges in the implementation.
Participants express differing opinions on the viability of the proposed linear generator approach, with some questioning its practicality and others exploring the technical details without reaching a consensus on its effectiveness.
Participants highlight various assumptions and dependencies, such as the specific properties of the magnet and coil, which could significantly influence the outcome. There are unresolved questions regarding the calculations and design parameters necessary for successful implementation.
kb_bkk
Hi. I want to make an assembly in which when one clicks a switch, it lights an infrared LED for 1/30 of a second.
Basically, instead of having a switch and a battery, i use a linear generator as a switch, giving current only when pressed to light LED. Like any linear generators, when one pushes the switch, the magnet (NIB) part moves along the center of the copper winding coils, creating currents. The whole process last a fraction of a second(just like pressing any mechanical switches).If i use the magnet of this shape (attachment file) with diameter 2cm and length 3cm with copper winding at outer surface of 900 turns(300x3 overlapping turns), and tap the magnet so it moves a short distance quickly through the windings like pressing switches, is there a possibility that it can light infrared LED 1.2 volt for 1/30th of a second? Has anyone ever done something similar? Will increasing thickness of the magnet ring from 1.5mmto 2mm matter significantly?
Thank you
Is there any particular reason you do not want to use a one-shot (monostable) or a piezoelectric button, like in the Aim n' Flame butane lighters?
You would have to have the coil only affected by one pole of the magnet. So, you would have your magnet outside the coil and being pushed into it.
If you did it like that, you would certainly get a pulse that you could see on an oscilloscope, but lighting a LED with it might be a different thing. I don't think you would get enough voltage under load, but the only way to be sure is to try it.
If you are trying to save having to use a battery, the effort might be misguided. You may have to spend a lot of time developing a suitable coil when simple remote controls do the same thing and the batteries last for years.
Hoo hoo,
Some questions you need to answer:
Is that magnet magnetized radially, diametrically, axially?
How many turns are in the coil?
What is the surface gauss (not BrMax gauss) of your magnet (convert to Tesla's)?
You won't be plugging in NIB into a Faraday equation.
What is the area of your coil, (in square meters of course)?
How fast will the magnetic field be moving towards, away from or parallel to the coil (in seconds)?
What happens if it moves slower or faster (in seconds)?
What is the resistance of the coil in ohms?
How does changing anyone of; turns, gauss, area of coil, or time affect the output?
How does wire size affect the area of a coil?
Pythagoras can help you too. You heard me Pythagoras, get over their !
How many diodes will it take to turn your Alternating current into Direct Current?
13K
  • · Replies 21 ·
15K
