Object drops vertically with a horizontal force acting on it
The problem involves a couch cushion of mass 1.22 kg released from a height of 8.48 m, subjected to a horizontal force of 2.42 N due to wind. The correct calculation shows that the cushion will land 1.72 m away from the building. The time taken for the cushion to fall is determined solely by the vertical motion, which is independent of the horizontal force acting on it. The equations of motion used include F=ma and xf-xi = vit + 0.5at².
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of kinematic equations for motion
  • Concept of independent motion in physics
  • Basic principles of projectile motion
  • Study the effects of horizontal forces on falling objects
  • Learn about projectile motion and its equations
  • Explore the concept of independent motion in physics
  • Investigate real-world applications of forces acting on falling objects
Physics students, educators, and anyone interested in understanding the dynamics of objects under the influence of multiple forces.
MechaMZ
A couch cushion of mass m is released from rest at the top of a building having height h. A wind blowing along the side of the building exerts a constant horizontal force of magnitude F on the cushion as it drops as shown in the figure. The air exerts no vertical force.
http://img3.imageshack.us/img3/5868/p563.gif
If m = 1.22 kg, h = 8.48 m, and F = 2.42 N, how far from the building will the cushion hit the level ground?
F=ma
xf-xi = vit+0.5at2
The time take for this situation should not be the same as an object is dropping vertically downward with 1.22kg, since there is a horizontal force acting on the current situation.
So I can't take the time as a common variable in between the free fall and this situation, but how to find out the variables?
the correct answer is 1.72 m
Unfortunately, the time taken is the same, as the vertical and horizontal velocities are independent of each other. Whether the object is moving towards the right or left with whatever velocity does not change or affect the vertical motion of the object.
  • · Replies 39 ·
13K
