Making a Magnetic Sail: Challenges & Benefits
  • Thread starter Thread starter sanman
    Magnetic
The discussion revolves around the challenges and potential benefits of creating a magnetic sail or magnetic plasma bubble to serve as a radiation shield for spacecraft. It explores technical hurdles associated with the implementation of such a concept, particularly in the context of using a nuclear reactor as a power source.
  • One participant identifies key challenges including the power plant needed to generate the current for the magnetic field, the configuration of conductors, magnetic intensity, and potential radiation leakage into living areas.
  • Another participant questions the mechanism by which charged particles would interact with the magnetic field, seeking clarification on whether they would be deflected or if the plasma itself would contribute to the charged particle dynamics.
  • A participant explains that charged particles in space, such as those from solar wind, travel along magnetic field lines, drawing a parallel to the formation of auroras and the operation of magnetic mirrors in fusion reactors.
  • One participant contrasts the ability of solid walls to stop incoming charged particles with the challenge posed by electromagnetic radiation, suggesting that the rotating field lines of the plasma magnet could help absorb incoming radiation and cushion against charged particles.
Participants express differing views on the effectiveness and mechanisms of the proposed magnetic sail concept, indicating that multiple competing perspectives remain without a clear consensus.
Limitations include assumptions about the efficiency of the power plant, the configuration of conductors, and the behavior of charged particles in relation to the magnetic field and plasma bubble. The discussion does not resolve the technical feasibility of the proposed ideas.
sanman
What are the challenges to making a magnetic sail, or a magnetic plasma bubble to surround a spacecraft as a radiation shield?
I was reading this:
http://www.ess.washington.edu/Space/PlasmaMag/
If we have a suitable nuclear reactor as our power source, then what are the chief technical challenges in achieving the rest of this idea?
In brief, the challenges are:
The power plant required to produced the current which produces the magnetic field.
The configuration of the conductors that carry the current that induces the magnetic field.
The magnetic intensity and the potential for leakage into the living areas (where astronauts reside).
The radiation (nuclei, electrons, and ions) that would travel along the field lines and increase brehmsstrahlung (EM) radiation and other secondary radiation in the vicinity of astronauts and sensitive electronics.
Just to better understand the last you made - do you mean incoming charged particles would travel along the field lines by mere coincidence, or are you saying that the magnetic field itself would deflect such incoming particles to travel along the field lines, or else are you referring to the plasma itself being the source of charged particles traveling along the field lines?
Charged particles in space (e.g. solar wind) travel along magnetic field lines. That's how auroras form - when charge particles travel along the lines, enter the atmosphere and ionize the gas atoms/molecules.
That's also the principle behind the magnetic mirrors in the tandem mirror (fusion) reactor.
But whereas incoming charged particles can be stopped by solid walls of a spacecraft , that's not necessarily the case for electromagnetic radiation.
My understanding of the plasma magnet described in the link above, is that the field lines are rapidly rotating, to keep a bubble of locally released ionized gas confined and enveloping the spacecraft . To me, this precludes allowing incoming particles to hit your spacecraft . The enveloping plasma is supposed to be able to absorb the incoming electromagnetic radiation, while acting as a cushion/sail against the incoming charged particle radiation, absorbing their momentum.
  • · Replies 16 ·
  • · Replies 46 ·
17K
  • · Replies 35 ·
