Curvature of a rectangular hyperbola
The discussion centers on the curvature of the rectangular hyperbola defined by the equation y = 1/x in the first quadrant, with a parametric representation of (x, y) = (t, 1/t) for t > 0. The curvature is calculated using the formula |f''(x)|/((1+(f'(x))^2)^(3/2)), leading to the expressions for f'(x) and f''(x). The correct curvature for the evolute is determined to be 1/2(1 + 1/(t^4))^(3/2), confirming that the term |t^3| is unnecessary in this context. The discussion highlights the importance of careful computation in deriving the evolute from the curvature.
  • Understanding of parametric equations and their derivatives
  • Familiarity with curvature formulas in differential geometry
  • Knowledge of hyperbolic functions and their properties
  • Proficiency in calculus, specifically second derivatives
  • Study the derivation of the evolute for different types of curves
  • Learn about the applications of curvature in physics and engineering
  • Explore advanced topics in differential geometry, such as geodesics
  • Investigate the relationship between curvature and surface properties
Mathematics students, educators, and professionals in fields requiring advanced calculus and geometry, particularly those focusing on the properties of curves and surfaces.
StarWrecker
The hyperbola y = 1/x in the first quadrant can be given the parametric definition (x, y) = (t, 1/t), t>0.
Find the corresponding parametric form of its evolute, and sketch both curves in the region 0<x<10, 0<y<10
Curvature formula:
I've worked through this in full, but there is a single term in my curvature that is throwing off my end result. My calculation of this curvature is as follows:
So
f'(x) = -1/(x^2)
f''(x) = 2/(x^3)
And therefore
k = |2/(x^3)|/((1/(x^4) + 1)^(3/2))
= 2/(|t^3| * (1 + 1/(t^4))^(3/2)) (as x is the same as the parameter t, (x, y) = (t, 1/t))
and p = 1/t = 1/2 * (1 + 1/(t^4))^(3/2) * |t^3|
But, the curvature which leads to the correct evolute for the curve (which is what I'm really looking for) is simply 1/2(1 + 1/(t^4))^(3/2), without the |t^3|. I've been working on this for an hour, and I still can't figure out why it disappears.
Hi,StarWrecker,I am 100 percent sure "p = 1/t = 1/2 * (1 + 1/(t^4))^(3/2) * |t^3|"
is correct.
And I am also sure that p(t) leads to the correct evolute for the curve.
Check your answer again and again,you will find out your errors on computation.
Yeah, I made a mistake in my later calculations for the evolute that I ironed out after trying my solution for the curvature again. Thanks.
  • · Replies 105 ·
13K
