Solve e^{\frac{-i \pi}{4}} = ?
  • Thread starter Thread starter Bacat
The discussion revolves around the expression e^{\frac{-i \pi}{4}} and its interpretation in the context of complex numbers, particularly using Euler's formula. Participants explore the implications of this expression and its relation to known identities such as Euler's Identity.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants examine the meaning of e^{\frac{-i \pi}{4}} in the complex plane, questioning the nature of its representation and whether it simplifies to a real constant. There is discussion about the outputs from Mathematica and their interpretations.
Some participants have provided clarifications regarding the outputs from Mathematica, noting that both representations of the complex number are valid. There is an ongoing exploration of the assumptions made about the expression and its simplifications, with no consensus reached on the interpretation of certain results.
Participants are navigating the complexities of complex exponentials and their representations, with some expressing confusion over the outputs from Mathematica and the implications of those results. There is a noted distinction between approximations and exact forms of complex numbers.
Bacat
Not really homework, but part of a homework problem I am working on.
I know that [tex]e^{i\pi}+1=0[/tex] (Euler's Identity)
And also that [tex]e^{i \pi} = e^{-i \pi}[/tex]
But I'm having trouble understanding [tex]e^{\frac{-i \pi}{4}}[/tex]
In the complex plane this is a clockwise rotation around the origin of [tex]\frac{\pi}{2}[/tex] radians. But I think it should reduce to some real constant which I am having trouble finding.
In Mathematica, I get two different answers...
[tex]N[e^{\frac{-i \pi}{4}}] = 0.707107 - 0.707107 i[/tex]
This implies that [tex]e^{\frac{-i \pi}{4}} = \frac{1}{\sqrt{2}}(1-i)[/tex] which seems wrong to me.
The other answer given is:
Simplify[tex][e^{\frac{-i \pi}{4}}] = -(-1)^{\frac{3}{4}}[/tex]
But this reduces to 1, which I believe is probably the correct answer.
Is the first result just spurious rounding?
Can I just write the following identity as true?
[tex]e^{\frac{-i \pi}{4}} = 1[/tex]
e^(-i*pi/4) isn't 1 by a long shot. e^(i*x) is cos(x)+i*sin(x). e^(-i*pi/4)=cos(-pi/4)+i*sin(-pi/4). Both of your Mathematica answers are correct. In fact they are the same (after rounding). And (-1)^(3/4) is NOT 1. Or -1 either.
Eh the first answer looks correct to me, since .707 is around sqrt(2)/2. You do know the Euler's formula, which is where those identities are usually derived from right?
No, the rotation is by [tex]\frac{\pi}{4}[/tex] radians. Was the 2 in the denominator a typo?
Why would you think that? Just because [tex]e^{-i \pi}[/tex] is a real constant, doesn't mean that the other one is also a real constant.
These are two representations of the same complex number. The first is an approximation and the second is exact.
I am not familiar with Mathematica, so I don't know the difference between the N command and the Simplify command.
No it doesn't, and 1 is not the correct answer. Let's look at -(-1)3/4 a little more closely. Before the final sign change, you have (-1) to the 3/4 power. That is the same as -1 cubed (still -1), which we take the 4th root of. This is not a real number, since there is no real number that when squared, and then squared again, yields a negative number. The final step is to change the sign of this (nonreal) number, which still doesn't give us 1, as you claimed.
Absolutely not.
Thanks Mark44 and all. This makes a lot more sense to me now.
  • · Replies 40 ·
