Range of f(x)=\sqrt{4-x^{2}} -2\leqx\leq2
  • Thread starter Thread starter temaire
    Function Range
The discussion revolves around finding the range of the function f(x) = \sqrt{4-x^{2}} within the interval -2 ≤ x ≤ 2. Participants explore various methods to determine the range, including graphical interpretations and algebraic manipulations.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Some participants suggest using a rough sketch of the graph or testing points to understand the behavior of the function. Others mention the importance of identifying the domain and the implications of the square root function. There are discussions about the appropriateness of using calculus versus algebraic methods for this problem.
The discussion is active, with participants providing various insights and methods for approaching the problem. There are differing opinions on the necessity of calculus in finding the range, and some participants question the completeness of the ranges provided by others. The conversation reflects a mix of interpretations and approaches without reaching a consensus.
Participants note that the problem is situated in a precalculus context, which raises questions about the appropriateness of certain methods, such as calculus, for solving the problem. There is also mention of the distinction between domain and range, indicating some confusion among participants.
temaire
Find the range of the function [tex]f(x) = \sqrt{4-x^{2}}[/tex]
[tex]f(x)=\sqrt{4-x^{2}}; -2\leqx\leq2[/tex]
[tex]f(2)=\sqrt{4-(2)^2}[/tex]
[tex]f(2)=\sqrt{4-4}[/tex]
[tex]f(2)=\sqrt{0}[/tex]
[tex]f(2)=0[/tex]
[tex]f(0)=\sqrt{4-(0)^2}[/tex]
[tex]f(0)=\sqrt{4}[/tex]
[tex]f(0)=2[/tex]
Range of [tex]f=[0,2][/tex]
I believe my answer is correct. What I am wondering is whether I'm showing my work properly. If I was to hand this into a prof/TA, would they dock me marks, and where?
Yes it could be answered better. This question is very simple so logic was easily used in this case, but let's try use a process that would help for more complicated questions.
First state that the range must be more than or equal to 0, since square root. So find the domain.
i.e.
[tex]\sqrt{4-x^2}\geq 0[/tex]
Now either by simply using a rough sketch of its graph, testing points, or some other means (or maybe even for your class' level, such a simple request is not expected), show [tex]-2\leq x\leq 2[/tex]
Now, take the function under the square root, and use calculus or some other means (in this case, the vertex of the parabola can be found)
e.g. [tex]y=4-x^2[/tex]
[tex]\frac{dy}{dx}=-2x[/tex]
Find the turning point ([tex]\frac{dy}{dx}=0[/tex]), show it is a maximum by the second derivative or stating that since it lies in the real domain of f(x), then it must be maximum, and now you have the range. [tex]0\leq f(x)\leq 2[/tex]
Mentallic it would be much easy if he wrote:
[tex]4-x^2 \geq 0[/tex]
[tex](2-x)(2+x) \geq 0[/tex]
Now (2-x)≥0 && (2+x)≥0 OR (2-x)≤0 && (2+x)≤0 :smile:
Now (2-x)>0 && (2+x)>0 OR (2-x)<0 && (2+x)<0 :smile:
How did you get that part?
njama said:
Two negative numbers give positive one right?
Just to mention, your range and Mentallic's range is not complete.
Actually, my range and Mentallic's range are complete. If you don't know how to find the range properly, please don't bother posting.
As a sidenote, you weren't even trying to solve for the range. There is a difference between domain and range.
Whoa! :eek: Again I misread the problem. So sorry. :cry:
Since [tex]f(x)=\sqrt{4-x^2}[/tex] is a continuous function, it is possible using calculus to determine the minimum and maximum values of f on its domain.
The domain is fairly easily determined to be [-2, 2].
Unfortunately without calculus it would be difficult to determine whether it is the case that f wanders above or below its values at -2 and 2.
For example [itex]g(x)=x^3-x \text{ for } -1 \leq x \leq 1[/itex] has values f(-1) = 0 and f(1) = 0, but the function has a range of [tex][-2\sqrt{3}/9, 2\sqrt{3}/9][/tex].
--Elucidus
Given that this was posted in the Precalculus forum, a solution using calculus is probably inappropriate. I don't know the OP's background, but it's likely that he or she has not studied calculus yet, so any help or hints in that direction are probably misplaced.
For this problem, calculus is unnecessary, unlike the problem you posed in the following example. For this problem, you can look at the behavior of the related function y = 4 - x2 to shape of the graph (and thereby determine the range). Then, one can look at the graph of [tex]y = \sqrt{4 - x^2}[/tex] to see how taking the square root affects the domain and range. No calculus needed.
--Elucidus
If you give an example, it's a good idea to give one that is similar enough to the original problem that the same sort of solution applies. That way you can convey the basic underlying ideas that can be applied to the original problem.
I guess the point I was hoping to make was not made well. My comment was motivated by trying to indicate that some functions' ranges require more advanced methods (like calculus) - I was giving an example of one of the more advanced problems.
I have frequently seen students try methods they've learned in earlier courses on problems for which that method was inappropriate not knowing the limitations of the technique. I often try to explain these limitations when presenting new methods - including an example for which it fails.
I agree the range for [itex]y = \sqrt{4-x^2}[/itex] can fortunately determined geometrically as you say. This method does not always work though.
--Elucidus
Right. And my point was that for a precalculus problem, the first technique to be explored or explained ought not to invoke techniques that involve calculus, but instead should appeal to the student's graphical sense or basic knowledge of functions. IMO, the simplest approach that will do the job is the one to start with. After the student understands that technique, then you can elaborate on other approaches, but not until then.
--Elucidus
Why not find the domain of the function's "inverse" and from that determine the range of the original function? I know it's not one-to-one, but it can help.
  • · Replies 23 ·
