The discussion revolves around the phenomenon of airplanes traveling through clouds and the perceived disturbance (or lack thereof) caused to the clouds. Participants explore aerodynamic principles, the effects of jet engines, and the visibility of disturbances within clouds.
- Exploratory
- Technical explanation
- Conceptual clarification
- Debate/contested
- One participant questions why a cloud would be disturbed by an airplane, suggesting that airplanes are designed to be aerodynamic and minimize air disturbance, likening it to a diver making little splash.
- Another participant acknowledges that clouds are indeed disturbed to some extent, indicating that there is some level of disturbance caused by airplanes.
- A different viewpoint suggests that while clouds may appear undisturbed, they actually are affected by the vortices produced by jet airliners, which can take a long time to dissipate and can create turbulence that is not visible from the ground.
- One participant emphasizes the importance of separation between aircraft due to the potential for violent turbulence left by a preceding airplane, particularly when approaching landing strips.
- A participant provides a link to a webpage that presumably illustrates relevant aerodynamic effects, although the content of the link is not discussed in detail.
Participants express differing views on the extent to which clouds are disturbed by airplanes. While some argue that clouds remain largely undisturbed, others contend that there is significant disturbance, particularly from vortices. The discussion remains unresolved regarding the visibility and impact of these disturbances.
There are limitations in the discussion regarding assumptions about visibility within clouds and the specific aerodynamic effects of different aircraft designs. The discussion does not resolve the complexities of these interactions.
