Special Relativity - Length Contraction Problem
The discussion focuses on the application of special relativity concepts, specifically time dilation and length contraction, to determine if a person can travel from the center to the edge of the galaxy within a normal lifetime of 100 years. The radius of the galaxy is given as 3x10^20 meters (30,000 light-years). The key equations discussed include the time dilation formula, dτ = dt √(1 - β²), and the length contraction formula, L = L₀ / γ, where γ is the Lorentz factor derived from the time dilation calculations. The user successfully calculated the necessary velocity using time dilation but struggled with applying length contraction correctly.
  • Understanding of special relativity concepts, including time dilation and length contraction.
  • Familiarity with the Lorentz factor (γ) and its calculation.
  • Basic knowledge of velocity calculations in the context of relativistic physics.
  • Ability to manipulate and apply equations involving proper length and observed length.
  • Study the derivation and application of the Lorentz factor (γ) in special relativity.
  • Learn how to correctly apply the length contraction formula in various scenarios.
  • Explore examples of relativistic velocity calculations and their implications in astrophysics.
  • Investigate the relationship between time dilation and length contraction in practical problems.
Students and enthusiasts of physics, particularly those studying special relativity, as well as educators looking for practical examples to illustrate complex concepts in relativistic motion.
DougD720
The radius of our galaxy is 3x10^20m (30000 lightyears).
(part a): Can a person in principle travel from the center to the edge of the galaxy in a normal lifetime? Explain using Time-Dilation, then Length-Contraction.
[tex]d\tau[/tex] = dt [tex]\sqrt{1 -\beta<sup>2</sup>}[/tex]
L = [tex]\acute{L}[/tex] / [tex]\gamma[/tex]
Okay so I've done part a - 1 which uses time-dilation and that went fine, part b asked for the velocity required to make the trip in 30 years, did that, no problems, but this length contraction is killing me. I've got a stack of (now) scrap legal-pad pages trying to figure this thing out. I think what I really need to know is where to plugin the radius of the galaxy (i tried using that as both the proper length and the observed length, but I'm not sure of which, both are giving me non-sensical answers), and short of using the beta I calculated from the time-dilation (0.9999499) i don't know how to get beta, I tried plugging in values for v such as replacing v with (displacement/time) but that didn't work because I don't know whether to use the radius of the galaxy as the displacement, or what. I don't need anyone to do the math for me, just someone to point me in the right direction of the values to plugin where.
Also, I considered a normal lifetime 100 years.
Thanks for the help!
If you did the time-dilation part and it went fine then you have gamma. Now imagine that you are in the spaceship traveling with the speed implied by this gamma relative to the galaxy. As far as you are concerned, the galaxy is shorter than 30,000 light years by that same factor gamma.
Thank you! I just didn't know if I could use the gamma from the time-dilation part, but yeah, duh, that makes perfect sense. Thanks!
  • · Replies 54 ·
  • · Replies 36 ·
  • · Replies 78 ·
  • · Replies 63 ·
  • · Replies 45 ·
