Limits, find the smallest +ve number N
  • Context: Undergrad
  • Thread starter Thread starter John O' Meara
    Limits
The discussion revolves around finding the smallest positive number N such that for each x in the interval (N, +infinity), the function f(x) = x/(x+1) is within 0.01 units of L = 1. Participants explore the implications of the definition of limits and the behavior of the function as x approaches infinity.
  • One participant suggests solving the equation x/(x+1) = 1 - 0.01 to find N.
  • Another participant questions the manipulation of the absolute value expression, specifically how to correctly interpret |f(x) - L| and its implications for N being positive.
  • A participant points out that the absolute value |(-1)/(x+1)| is equal to |1/(x+1)|, emphasizing that this does not lead to a negative N.
  • There is a numerical example provided to illustrate a point about inequalities, indicating that some participants are using specific cases to clarify their arguments.
Participants do not reach a consensus on the correct approach to finding N, and there are competing views on the manipulation of the mathematical expressions involved.
There are unresolved mathematical steps regarding the manipulation of absolute values and the implications for the positivity of N. The discussion reflects varying interpretations of the limit definition and its application.
John O' Meara
Find the smallest positive number N such that for each x in the interval (N,+infinity) the value of [tex]f(x)= \frac{x}{x+1}[/tex] is within .01 units of L=1.
From the definition [tex]|f(x)-L|<\epsilon \mbox{ if } x > N, \epsilon>0, N>0[/tex]. It follows that [tex]|\frac{x}{x+1}-1| < \epsilon \mbox{ if } x > N \mbox{ therefore } |\frac{-1}{x+1}| < \epsilon \mbox{ if } x > N[/tex] Now if I move the minus sign across to epsilon I get [tex]|\frac{1}{x+1}| > -\epsilon \mbox{ if } x > N[/tex]. But epsilon is positive and so is x and so is N yet I will get a negative answer for N according to the last statement. Can anyone clarify the argument needed to get [tex]|\frac{-1}{x+1}| = |\frac{1}{x+1}|[/tex] so that N can remain positive? Thanks
i didn't read all that (have to catcha bus) but can't you just go x/(x+1) = 1-0.01 and solve for x?
Yes, you can just solve for x as you say.
John O' Meara said:
[tex]\left|\frac{-1}{x+1}\right| < \epsilon \mbox{ if } x > N[/tex] Now if I move the minus sign across to epsilon I get [tex]\left|\frac{1}{x+1}\right| > -\epsilon \mbox{ if } x > N[/tex]
How'd you do that?
P.S. use \left| and \right| to make big bars.
No, since that is an absolute value, it is larger that negative epsilon for all n.
[itex]|\frac{-1}{x+1}|= |\frac{1}{x+1}|< \epsilon[/itex] says that [itex]-\epsilon< \frac{1}{x+1}< \epsilon[/itex]
Hurkyl, I used a numerical example -5< 4 therefore 5 > -4. Thanks for pointing out my error.Thanks all for the replies.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 18 ·
