Is Your Solution to the Linear Differential Equation Unique?
  • Thread starter Thread starter calvert11
    Linear Uniqueness
The discussion focuses on solving the initial value problem (IVP) represented by the linear differential equation ty' + (t-2)y = (t^4)e^t with the initial condition y(0) = 0. The theorem states that if p(t) and g(t) are continuous on an interval containing t0, a unique solution exists. However, since p(t) = (t-2)/t is undefined at t = 0, the theorem fails, indicating that the solution may not be unique. The participants clarify that while y(t) = 0 is a solution, the initial condition does not yield a unique solution.
  • Understanding of linear differential equations
  • Familiarity with initial value problems (IVPs)
  • Knowledge of continuity in functions
  • Ability to identify integrating factors in differential equations
  • Study the concept of integrating factors in linear differential equations
  • Explore the implications of the existence and uniqueness theorem for differential equations
  • Learn how to solve linear differential equations with discontinuous coefficients
  • Investigate piecewise functions and their applications in differential equations
Students studying differential equations, mathematics educators, and anyone interested in the properties of initial value problems and their solutions.
calvert11
Solve the IVP. Is your solution unique? Explain.
ty' + (t-2)y = (t^4)*(e^t)
y(0)=0
Theorem:
If p(t) and g(t) are continuous functions on an open interval a< t < b and the interval contains t0, then there is a unique solution to the IVP on that interval.
I'm rather sure I've solved the equation correctly, but I end up with something like this:
y = [tex]\frac{t^2}{e^t}[/tex] X [...etc.]
Now if I input the initial values, I get 0 = 0.
Furthermore, since p(t) = (t-2)/t where t cannot = 0, the Theorem would fail as no interval exists that satisfies it.
So, I'm a bit confused about how to answer this question. Assuming I solved the equation correctly, is 0 = 0 a solution? And since the equation fails the Theorem does that mean it is not unique? I do hope I'm making sense.
y(0)=0
Theorem:
This is certainly NOT a solution to the equation. It is an integrating factor for the equation. Is that what you meant?
So, I'm a bit confused about how to answer this question. Assuming I solved the equation correctly, is 0 = 0 a solution?[/quote]
No, "0= 0" is not a 'solution', it isn't even a function. It is true that y(t)= 0, for all t, is a solution.
That means it may not be unique. Can you find another function satisfying that differential equation and initial value? Hint: Can you solve that differential equation with y(1)=0. Now, what if you took y(t)= 0 for t< 1 and y(t)= that solution for y> 1?
No, I found the integrating factor to be [tex]\frac{e^t}{t^2}[/tex]
lol yeah. that was a silly question. So would y(0)=0 have no solution then?
Sorry, I'm really unaccustomed to using the layout tools here so please bare with me. This is "in general" what I came up with before putting in the initial values y(0)=0
y = (t^2/e^t)*[...etc. + C] where C is some constant. Obviously 0^2 = 0 so everything in the brackets becomes 0 and since y = 0 then 0 = 0.
let me try that. but would you mind giving some input on what I've written above?
