How to Use AWK to Generate a Series of Numbers in a Shell Script
  • Thread starter Thread starter confi999
The discussion revolves around generating a series of numbers in a shell script using AWK or alternative methods. Participants explore how to modify a script to produce a specific output format with sequential numbers in the last column.
  • Homework-related
  • One participant requests assistance in generating a series of numbers from 1 to 500 in a specific format using AWK.
  • Another participant suggests using the AWK command `awk '{ print $0, ++x; }'` to append numbers to the end of each line.
  • A participant expresses the desire to create a complete script that generates all 500 lines with the specified format.
  • A shell script is provided by a participant that uses a loop to echo the desired output format for numbers 1 through 500.
There is no explicit disagreement noted, as participants build upon each other's suggestions and provide solutions without contesting the validity of the approaches presented.
Participants do not clarify the specific requirements or constraints of the script beyond the output format, leaving some assumptions about the context of use unaddressed.
This discussion may be useful for individuals looking to automate the generation of formatted output in shell scripts, particularly those interested in using AWK or shell scripting techniques.
confi999
Hi,
I need to modify a shell script and add the following into it:
I thought using some awk command one could produce the series 1,2,... 500 in the last column of all the 500 lines. Can anyone help me with that command.
Thank you very much.
confi999 said:
Hi,
if you just want a filter to add numbers to the end of each line...
Hi,
Thanks!
I want to write a small script or an awk command (or if any other way) that will produce a file which has all those 500 lines in it.
confi999 said:
Hi,
Thanks!
Here's a shell script
Code:
#!/bin/sh
for (( n=1 ; n <= 500 ; n++ )) do
    echo location: 200 200 $n
done
Code:
#!/bin/sh
done
Thank you sooo much.
  • · Replies 96 ·
13K
  • · Replies 31 ·
