Register to reply
Eigenvalues of a 4x4 matrix and the algebraic multipicities
by andrelutz001
Tags: algebraic, eigenvalues, matrix, multipicities
Share this thread:
andrelutz001
#1
Sep16-09, 07:55 AM
P: 6
Hi everyone
Consider the following 4 x 4 matrix:
A = [[6,3,-8,-4],[0,10,6,7],[0,0,6,-3],[0,0,0,6]]
Find the eigenvalues of the matrix and their multiplicities. Give your answer as a set of pairs:
{[lambda1,multiplicity1],[lambda2,multiplicity2],........}
2. Relevant equations
det(A-λI)=0
3. The attempt at a solution
Set up the characteristics equation and solve it:
A = [[6,3,-8,-4],[0,10,6,7],[0,0,6,-3],[0,0,0,6]] det(A-λI)= [[6-λ,3,-8,-4],[0,10-λ,6,7],[0,0,6-λ,-3],[0,0,0,6-λ]]
This is the part where I think I am likely to make a mistake since it is rather difficult to factorize the characteristic polynomial using conventional methods(by hand).
Therefore after a few steps the characteristic polynomial for the above matrix is:
(λ^4)-(28*λ^3)+(288* λ^2)-(1296 *λ)+2160
Factorizing the characteristic polynomial yields:
((λ-10)(λ-6)^3)
Looking at the problem statement again, the question asks to find the eigenvalues and the algebraic multiplicities.
λ-10=0 therefore λ1=10
λ-6=0 therefore λ2=6
I know that the term algebraic multiplicity of an eigenvalue means the number of times it is repeated as a root of the characteristic equation.
With this in mind I am inclined to state that for λ1=10 the algebraic multiplicity is 1 and for
λ2=6 the algebraic multiplicity is 3.
Therefore the answer as a set of pairs mentioned above {[lambda1,multiplicity1],[lambda2,multiplicity2],........} is {[10,1],[6,3]}
I have made a good attempt at solving this question, am I on the right track?
Thank you in advance,
Andrei
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Dick
#2
Sep16-09, 08:22 AM
Sci Advisor
HW Helper
Thanks
P: 25,244
I don't see any problems. But you did work too hard to find the characteristic polynomial. Your matrix is upper triangular. If you had used a determinant method like expansion by minors, you would have gotten the determinant to come out directly as (6-λ)*(10-λ)*(6-λ)*(6-λ). Only the diagonal elements contribute.
andrelutz001
#3
Sep16-09, 08:40 AM
P: 6
Thank you
Register to reply
Related Discussions
Eigenvalues + Algebraic/Geometric Multiplicity Calculus & Beyond Homework 2
Eigenvalues of n x n matrix Calculus & Beyond Homework 2
Eigenvalues of a matrix Calculus & Beyond Homework 22
Eigenvalues of a 2 by 2 matrix Calculus & Beyond Homework 9
Algebraic manipulation of identity matrix Linear & Abstract Algebra 4
