Thread Closed
Conservation of momentum in an inelastic collision
Share Thread Thread Tools
Sep17-09, 06:28 AM   #1
The law of conservation of momentum states that all momentum is conserved in a collision. Momentum is defined as p = mv. When a collision occurs, most of the time a lot of velocity is lost and most of the mass remains. For example, a fast moving trolley runs into a brick wall, after hitting the brick wall no mass is lost or gained but a significant amount of velocity is lost. Using the formula p = mv, the final momentum will be lower than the initial momentum.
Also, impulse can be defined as the change in momentum. But isn't momentum always conserved?
This seems to be an obvious paradox but I know that I've got something wrong so can someone please lead me in the write direction. Cheers
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Sep17-09, 07:12 AM   #2
Mentor
Quote by sugaJ View Post
The total momentum is conserved in a collision. The individual momenta of the various bodies will certainly change--forces are being exerted on them.
Momentum is conserved in the absence of external forces.
No. If something experiences a force--thus an impulse--its momentum will change.
When the trolley runs into the wall, the wall and trolley exert forces on each other. The trolley loses momentum and the wall (and the attached earth) gains momentum. (You won't notice the change in the wall's momentum since the wall+earth is so massive.)
Sep17-09, 04:17 PM   #3
yep makes sense thanks mate
Thread Closed
Tags
momentum impulse
Thread Tools
Similar Threads for: Conservation of momentum in an inelastic collision
Thread Forum Replies
Conservation of Momentum in an Inelastic Collision Introductory Physics Homework 26
Inelastic collision and Kinetic Energy Conservation Introductory Physics Homework 2
Momentum! INELASTIC COLLISION! Introductory Physics Homework 13
[SOLVED] Conservation of linear momentum and inelastic collision Introductory Physics Homework 9
Inelastic collision and conservation of energy Introductory Physics Homework 2
