AVR STUDIO (compiling C and running)
  • Thread starter Thread starter tenacity2986
    Running
The discussion focuses on compiling C code using AVR Studio and running it on an AVR microcontroller. Users must understand that the AVR Compiler generates AVR machine code, which requires hardware to execute. For simple output testing, participants suggest using an LED connected to a microcontroller pin instead of relying on JTAG or serial connections. Additionally, alternatives like GCC, Visual C++, and XCode are recommended for those seeking simpler environments for C programming.
  • Understanding of AVR microcontroller architecture
  • Familiarity with AVR Studio and its compilation process
  • Basic knowledge of C programming and embedded systems
  • Experience with hardware connections, such as using LEDs and resistors
  • Learn how to set up and use the GCC compiler for embedded systems
  • Research how to connect and program AVR microcontrollers using serial communication
  • Explore Visual C++ for Windows development of C programs
  • Investigate XCode for developing C applications on macOS
Embedded systems developers, hobbyists working with AVR microcontrollers, and anyone interested in learning C programming in a hardware context.
tenacity2986
okay i can compile the c file fine. but when i run it, its trying to connect through jtag and hardware. I just want to see the output of the compiled program! any1 know how? thankyouu verry much
Are you aware that the AVR Compiler compiles to AVR machine code and needs to be run on an AVR microcontroller? If so (sorry, have to cover all the bases), and you're using a printf statement or two, that means that you need to wire up a DB-9 connector, hook it up to your computer's serial port, and use a terminal program to take input.
If you don't want to go to all that trouble (or lack serial ports and/or a serial-to-USB converter), and you're just looking to do some kind of "Hello world!" thing, just hook up an LED and a resistor in series to one of the pins, and have it light up:
Code:
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 8000000UL //change to whatever
void _delay_1s(void)
//1s delay routine
	int n;
	for(n=0; n<50; n++)
	{	_delay_ms(20);	}
int main(void)
	DDRA |= 1 << PINA7;
	PORTA |= 1 << PINA7;
	for(;;)	//toggle PIN A7 every second
		_delay_1s();
		PORTA ^= (1 << PINA7);	//XOR existing value to toggle
If not, and you're just looking for something to do a very simple program in, look into how to use the GCC compiler (Linux), Visual C++ (Windows, the personal edition is free), or XCode (Mac--also free)
  • · Replies 0 ·
  • · Replies 29 ·
12K
