Why is the difference in electric potential negative?
  • Thread starter Thread starter PeterPumpkin
    Negative Sign
The difference in electric potential between points A and B is defined as the negative of the work done in moving a test charge along the path from A to B, divided by the charge q. This negative sign arises because the work done by a conservative force, such as gravity, is the negative of the change in potential energy. For example, when an object is tossed upwards, the work done by gravity is negative, leading to a positive change in potential energy. Thus, the negative sign indicates that energy removed from an object through negative work must be stored as an increase in potential energy.
  • Understanding of electric potential and potential energy concepts
  • Familiarity with conservative forces and work-energy theorem
  • Basic knowledge of mechanics, particularly kinetic and potential energy
  • Ability to interpret equations involving work and energy
  • Study the relationship between work and energy in conservative force fields
  • Explore the implications of the work-energy theorem in different physical scenarios
  • Learn about electric fields and their impact on electric potential
  • Investigate the mathematical derivation of electric potential equations
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of electric potential and energy conservation in conservative systems.
PeterPumpkin
Why is the difference in electric potential between points A and B defined as the NEGATIVE of the work done in moving a test charge along the path from A to B and then dividing by the charge q? Why the negative sign? Just wondering.
Delta V = - Work done / q
This is more general than charges. The work done by a conservative force is the negative of the change in potential energy. Why the negative sign? Think of it this example. Say I toss an object straight up in the air (no air resistance). The work energy theorem says that the change in kinetic energy is the work done by the net force, in this case gravity. The work done by gravity for an object that moves up is negative. Therefore, ΔK = - mgh. The change in potential energy is positive, ΔU = + mgh so that ΔK = - ΔU or ΔK + ΔU = 0 which is mechanical energy conservation with the work done by the conservative force taken out of the picture.
The minus sign basically says that if you take out Joules from the energy of an object by doing negative work on it with a conservative force, then you'd better store these Joules as an increase in potential energy. Conversely, if you add Joules to an object by doing positive work with a conservative force, then these Joules better come from a decrease in potential energy.
Work done against a force field is signed positive, that's why there is a negative sign!
[tex]dW = - \vec F \cdot d\vec r[/tex]​
(note that like charges push off each other!)
with best regards!
  • · Replies 22 ·
