| Thread Closed |
Need urgent help ...verilog code error |
Share Thread | Thread Tools |
| Sep19-09, 02:50 AM | #1 |
Hello ,
I am new to verilog ...can someone help me urgent .. I have a task for 8 bit register where in i have to model hierarchial modeling ....... here are my modules .... correct me please Someone please patietnly go through all modules and let me know whas wrong in it .... `timescale 1ns/1ns module register(reg_out,data,ena,clk,rst); output [7:0] reg_out; input [7:0] data; input ena,clk,rst; regmux register0(reg_out[0],q,data[0],ena,clk,rst); regmux register1(reg_out[1],q,data[1],ena,clk,rst); regmux register2(reg_out[2],q,data[2],ena,clk,rst); regmux register3(reg_out[3],q,data[3],ena,clk,rst); regmux register4(reg_out[4],q,data[4],ena,clk,rst); regmux register5(reg_out[5],q,data[5],ena,clk,rst); regmux register6(reg_out[6],q,data[6],ena,clk,rst); regmux register7(reg_out[7],q,data[7],ena,clk,rst); endmodule `timescale 1ns/1ns module regmux(r,q,d,ena,clk,rst); output r; input q,d,ena,clk,rst; wire x,qb; MUX2to1 muxinst(x,q,d,ena); dff dffinst(q,qb,rst,clk,x); endmodule `timescale 1ns/1ns module MUX2to1(x,q,data,enable); output x; input q,data,enable; wire q1,data1,enablebar; not (enablebar,enable); and (q1,q,enablebar); and (data1,data,enable); or (x,data1,q1); endmodule ~ `timescale 1ns/1ns module dff(q,qb,clear,clock,data); output q,qb; input clock,data,clear; wire cb,clr,clkb,clk,db,d,s,sb,r,rb; defparam SR1.x=4.8,SR2.x=4.5,SR3.x=5; defparam SR1.y=3.3,SR2.y=4.5,SR3.y=4.5; not #(2.3) not1(cb,clear); not #(2.Cool not2(clr,cb); not #(2.3) not3(clkb,clock); not #(2.5) not4(clk,clkb); not #(2.3) not5(db,data); not #(2.3) not6(d,db); SR_Latch2 SR1(s,sb,clr,clk,1'b1,rb); SR_Latch2 SR2(r,rb,clk,s,d,clr); SR_Latch2 SR3(q,qb,1'b1,s,clr,r); endmodule ~ `timescale 1ns/1ns module SR_Latch2(Q,Qb,s0,s1,r0,r1); output Q,Qb; input s0,s1,r0,r1; parameter x=4.5; parameter y=4.5; nand #(x) nand1(Q,s0,s1,Qb); nand #(y) nand2(Qb,r0,r1,Q); endmodule i am getting tthis error ....ncvlog: *E,EXPMPA (regmux.v,21|0): expecting the keyword 'module', 'macromodule' or 'primitive'[A.1]. Total errors/warnings found outside modules and primitives: errors: 1, warnings: 0 ncverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1). .. Therre is error regmux module ..but seems to be evrything perfect ....can someone help .... Also i doubt there is soehting wrong with parameter overriding ..also need helo in it ,,,,, Thanks Rose |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Need urgent help ...verilog code error
| Urgent. Matlab Code of matrix multiplication | Math & Science Software | 13 | ||
| Error 112 /undef when running fortran code | Programming & Comp Sci | 8 | ||
| spot the error in my code. (in C). | Programming & Comp Sci | 11 | ||
| Convolution Code and Error Correcting Capability | Electrical Engineering | 2 | ||
| Convolution Code and Error Correcting Capability | General Math | 0 | ||
