How do I find expectation values for a particle in an infinite well?
The discussion focuses on calculating expectation values for a particle in an infinite potential well defined by the potential V(x)=0 for -a/4 < x < 3a/4. The wavefunction is determined as ψ(x)=√(2/a)sin[nπ/a(x+a/4)]. The user successfully computes as a/4 but encounters difficulties with , leading to confusion over unit consistency in their calculations. The correct expression for is suggested to be a^2(7n^2π^2-24)/64n^2π^2, and the user inquires about the validity of calculating
as zero based on the time derivative of .
  • Quantum mechanics fundamentals, specifically the concept of wavefunctions.
  • Integration techniques, including integration by parts.
  • Understanding of expectation values in quantum mechanics.
  • Familiarity with trigonometric identities and their application in integrals.
  • Study the derivation of expectation values in quantum mechanics using wavefunctions.
  • Learn advanced integration techniques, particularly integration by parts in the context of quantum mechanics.
  • Explore the implications of potential wells on particle behavior and energy states.
  • Investigate the role of operators in quantum mechanics, specifically how to apply them to calculate momentum.
Students and professionals in quantum mechanics, physicists working with wavefunctions, and anyone involved in theoretical physics calculations related to potential wells.
E92M3
I want to find <x> and ,<x^2>, <p>, and <p^2> of a particle in an infinite well where:
[tex]V(x)=0, \frac{-a}{4}<x<\frac{3a}{4}[/tex]
Using the usual method, I found the wavefunction to be:
[tex]\psi(x)=\sqrt{\frac{2}{a}}sin[\frac{n\pi}{a}(x+\frac{a}{4})][/tex]
I also found:
[tex]<x>=\frac{2}{a}\int_{\frac{-a}{4}}^{\frac{3a}{4}}xsin^2[\frac{n\pi}{a}(x+\frac{a}{4})]dx=\frac{a}{4}[/tex]
<x^2> is where I encounter the 1st problem. Here's my attempt:
[tex]<x^2>=\frac{2}{a}\int_{\frac{-a}{4}}^{\frac{3a}{4}}x^2sin^2[\frac{n\pi}{a}(x+\frac{a}{4})]dx[/tex]
Using by parts I let:
[tex]u=x^2[/tex]
[tex]du=2xdx[/tex]
[tex]dv=sin^2[\frac{n\pi}{a}(x+\frac{a}{4})]dx[/tex]
[tex]v=\frac{x}{2}-\frac{a}{2n\pi}sin[\frac{n\pi}{a}(x+\frac{a}{4})]cos[\frac{n\pi}{a}(x+\frac{a}{4})]=\frac{x}{2}-\frac{a}{4n\pi}sin[\frac{2n\pi}{a}(x+\frac{a}{4})][/tex]
(double angle formula used)
[tex]<x^2>=uv-\int vdu=\frac{2}{a}\left [ \left ((x^2)(\frac{x}{2}-\frac{a}{4n\pi}sin[\frac{2n\pi}{a}(x+\frac{a}{4})]) \right )_{\frac{-a}{4}}^{\frac{3a}{4}} -\int_{\frac{-a}{4}}^{\frac{3a}{4}}2x(\frac{x}{2}-\frac{a}{4n\pi}sin[\frac{2n\pi}{a}(x+\frac{a}{4})])dx\right ][/tex]
[tex]=\frac{2}{a}\left [ \frac{27a^3}{128}-\frac{-a^3}{128}-\int_{\frac{-a}{4}}^{\frac{3a}{4}}x^3dx+\frac{a}{4n\pi}\int_{\frac{-a}{4}}^{\frac{3a}{4}}2xsin[\frac{2n\pi}{a}(x+\frac{a}{4})])dx\right ][/tex]
[tex]=\frac{2}{a}\left [ \frac{7a^3}{32}-\frac{5a^4}{64}+\frac{a}{2n\pi}\left ( \frac{a^2}{4n^2\pi^2}sin[\frac{2n\pi}{a}(x+\frac{a}{4})])-\frac{a}{2n\pi}xcos[\frac{2n\pi}{a}(x+\frac{a}{4})])\right )_{\frac{-a}{4}}^{\frac{3a}{4}}\right ][/tex]
Sine term vanishes at both limits while cosine term as 1 at both limits:
[tex]=\frac{2}{a}\left [ \frac{7a^3}{32}-\frac{5a^4}{64}+\frac{a}{2n\pi}\left ( \frac{-3a^2}{8n\pi}+\frac{a^2}{8n\pi} \right )\right ]=\frac{7a^2}{16}-\frac{a^2}{4n^2\pi^2}-\frac{5a^3}{32}=\frac{a^2(7n^2\pi^2-4)}{16n^2\pi^2}-\frac{5a^3}{32}[/tex]
This is obviously wrong since the units don't add up/ How can there be a^2 and a^3 at the same time? I spend hours checking and still can't find my mistake.
I plug the equation into a graphic calculator, I think the answer should be:
[tex]\frac{a^2(7n^2\pi^2-24)}{64n^2\pi^2}[/tex]
Now, for <p>, can I just have:
[tex]<p>=m\frac{d<x>}{dt}=m\frac{d}{dt}\frac{a}{4}=0[/tex]
Is this alright or do I have to plug the operator in and integrate?
I think I spot your mistake: from the line in <x^2>=... in the integral you pass from
[itex]\int_{\frac{-a}{4}}^{\frac{3a}{4}}2x(\frac{x}{2})dx[/itex] in the firs line to [itex]\int_{\frac{-a}{4}}^{\frac{3a}{4}}x^3dx[/itex] in the second one
  • · Replies 19 ·
