Matrix of Transformation (non standard basis)
The discussion centers on the linear transformation T defined from R3 to R3 by T(x1, x2, x3) = (x1, x1 + x2, x1 + x2 + x3). The matrix representation [T] relative to the standard basis is confirmed as [[1, 0, 0], [1, 1, 0], [1, 1, 1]]. The transformation matrix [T]' relative to the basis B' = {(1,0,0)T, (1,1,0)T, (1,1,1)T} was initially miscalculated but corrections were provided. The transition matrix Q from the standard basis to B' was also derived, with an emphasis on ensuring the accuracy of the inverse matrix calculations.
  • Understanding of linear transformations and their properties
  • Familiarity with matrix representation of transformations
  • Knowledge of basis transformations in vector spaces
  • Ability to compute matrix inverses
  • Study the properties of linear transformations in depth
  • Learn how to derive transition matrices between different bases
  • Practice calculating matrix inverses and their applications
  • Explore examples of linear transformations in higher dimensions
Students and educators in linear algebra, mathematicians working with vector spaces, and anyone involved in computational mathematics or applied linear transformations.
margaret37
Define T : R3x1 to R3x1 by T = (x1, x2,x3)T = (x1, x1+x2, x1+x2+x3)T
1 Show that T is a linear transformation
2 Find [T] the matrix of T relative to the standard basis.
3 Find the matrix [T]' relative to the basis
B' = {(1,0,0)t, (1,1,0)t, (1,1,1)t
4 Find the transition matrix Q from B to B'
5 Verify that [T]' = Q[T]Q-1
1) I think this is done I showed that T(c(alpha + beta)) = c* T(alpha) + T(Beta) by substituting in vectors (a1, a2, a3) and (b1,b2,b3) and working through the algebra.
2) This is what I did, I think I understood this properly:
I built a transformation Matrix [T] = T(e1) | T(e2) | T(e3)
I got
1 0 0
1 1 0
1 1 1
3) Then I think is wrong but I'm not sure
I built another matrix [T]' = T(v1) | T(v2) | t(v3)
where v1, v2, and v3 are the the vectors given above
I got
1 1 1
1 2 2
2 2 3
4) Then I built a transformation matrix by finding the coordinates of e1, e2, and e3 relative to v1, v2 and v3
I got
1 -1 0
0 1 -1
0 0 1
I calculated an inverse
1 1 0
0 1 1
0 0 1
5) Then if I had done everything right
[T]' should have been equal to Q[T]Q-1
But it wasn't even close
1 1 1
0 1 1
0 0 1
Any help would be greatly appreciated.
Margaret
I got
1 1 1
1 2 2
2 2 3
One error is that T(v1) should be (1,1,1)t instead of (1,1,2)t. A more important error is that the resulting numbers "1,1,1" are coefficients with respect to the standard basis, not B'. You need to figure out x, y, and z such that
(1,1,1)t=x v1 + y v2 + z v3. This is easy to do by inspection: x=0, y=0, z=1. The first column of [T]' is therefore (0,0,1)t. Do a similar computation for T(v2) and T(v3). The appropriate coefficients x, y, and z are easy to find by inspection, although not as trivial as for T(v1).
Also, the inverse of
1 -1 0
0 1 -1
0 0 1
is almost but not quite
1 1 0
0 1 1
0 0 1
The row 1 column 3 entry is incorrect.
Thank you very much. I think I've got it now.
