Is My Quantum Mechanics Probability Calculation Correct?
The discussion focuses on the calculation of the probability for simultaneous measurements of position (x) and momentum (p_z) in quantum mechanics, specifically using the normalized wave function \(\psi(\vec{r})\). The user derived an expression involving integrals over position and momentum space, but seeks validation of their approach and whether a simpler method exists. Key equations referenced include the transformation between position and momentum states, specifically \(\langle \vec{p}|\vec{r}\rangle\) and \(\langle \vec{p}|\psi\rangle\). The use of projectors \(P_1\) and \(P_2\) to evaluate the expression \(\langle \psi|P_2P_1|\psi\rangle\) is also discussed.
  • Understanding of quantum mechanics wave functions
  • Familiarity with the mathematical formalism of quantum states and operators
  • Knowledge of integrals in multiple dimensions
  • Experience with the concepts of position and momentum space in quantum mechanics
  • Study the derivation of the position-momentum representation in quantum mechanics
  • Learn about the use of projectors in quantum state measurements
  • Explore simplifications in quantum probability calculations
  • Investigate the implications of the uncertainty principle on simultaneous measurements
Students of quantum mechanics, physicists working on quantum state measurements, and researchers interested in the mathematical foundations of quantum probability calculations.
facenian
Let [tex]\psi(x,y,z)=\psi(\vec{r})[/tex] be the normalized wave function of a particle.Express in terms of [itex]\psi(\vec{r})[/itex] the probability for a simultaneous measurements o X y P_z to yield :
[tex]x_1 \leq x \leq x_2[/tex]
[tex]p_z \geq 0[/tex]
[tex]<\vec{p}|\vec{r}>=\frac{1}{(2\pi\hbar)^{3/2}}e^{-i\vec{p}.\vec{r}/\hbar}[/tex]
[tex]<\vec{p}|\psi>=\frac{1}{(2\pi\hbar)^{3/2}}\int \psi(\vec{r}) e^{-i\vec{p}.\vec{r}/\hbar} dr^3[/tex]
I have reached the following result:
[tex]\int_{-\infty}^{\infty}dz\int_{-\infty}^{\infty}dy\int_{x_1}^{x_2}dx \int_{-\infty}^{\infty}dp_x\int_{-\infty}^{\infty}dp_y\int_0^{\infty}dp_z <\vec{p}|\vec{r}>\psi(\vec{r})<\psi|\vec{p}>[/tex]
I need to know two things: 1) is my result correct? 2) in case it is correct, is there any other more simple or concrete answer?
Sorry, I am not answering your question. But could you explain how you arrived at the expression [tex]<\vec{p}|\vec{r}>\psi(\vec{r})<\psi|\vec{p}> [/tex]
I evalueted de expression [itex]<\psi|P_2P_1|\psi>[/itex] where P_1 and P_2 are the proyectors:
[tex]P_1=\int_{-\infty}^{\infty}dz\int_{-\infty}^{\infty}dy\int_{x_1}^{x_2}dx|x,y,z><x,y,z|[/tex]
[tex]P_2=\int_{-\infty}^{\infty}dp_x\int_{-\infty}^{\infty}dp_y\int_0^{\infty}dp_z|p_x,p_y,p_z><p_x,p_y,p_z|[/tex]
But I'm sure whether what I'm doing is correct
  • · Replies 30 ·
