Efficiency of Tractor Mounted Equipment: Max 200nm Torque, 60HP
  • Thread starter Thread starter tony t
    Hi
The discussion focuses on the efficiency of tractor-mounted equipment powered by a diesel engine with a maximum torque of 200 Nm and 60 HP at 1500 RPM. The user seeks to understand the horsepower available at a reduced shaft speed of 100 RPM after gearing adjustments. The conversation highlights the need for a comparison with hydraulic options, indicating a lack of information regarding efficiency metrics in the current context.
  • Understanding of diesel engine specifications, including torque and horsepower.
  • Knowledge of gear ratios and their impact on output RPM.
  • Familiarity with efficiency calculations in mechanical systems.
  • Basic concepts of hydraulic systems for comparative analysis.
  • Research "Torque and horsepower relationship in diesel engines".
  • Explore "Calculating efficiency in mechanical systems".
  • Learn about "Gear ratio effects on output power and RPM".
  • Investigate "Hydraulic systems vs. mechanical systems in agricultural equipment".
Agricultural engineers, equipment manufacturers, and anyone involved in optimizing tractor-mounted equipment performance.
tony t
I want to know efficiency of a tractor mounted equipment.
my input is only this--
tractor is a diesel engine powerd one with max. 200nm torque ,6o hp.@1500 rpm.
the equipment runs on 100 rpm after a series of gearing.
i just want a rough idea about efficiency.
how mutch H.p. available at 100 rpm shaft.
i want to compair it with hydraulic option.
Sorry, nothing about that tells us anything about efficiency.
  • · Replies 19 ·
10K
  • · Replies 26 ·
23K
9K
  • · Replies 82 ·
29K
