How do you solve the integral of (sin(x)/x)^2?
  • Thread starter Thread starter Susanne217
    Dx
The discussion revolves around evaluating the integral \(\int_{-\infty}^{\infty} \left(\frac{\sin(x)}{x}\right)^2 dx\), which falls under the subject area of calculus, specifically improper integrals and trigonometric identities.
  • Participants explore various approaches to evaluate the integral, including breaking it into parts and using trigonometric identities. There is mention of using Taylor series expansions and the potential for applying Fourier transforms. Some participants question the effectiveness of certain methods and express uncertainty about the calculations involved.
The discussion is ongoing, with participants providing insights and alternative methods for evaluating the integral. Some guidance has been offered regarding the use of symmetry and switching the order of integration, but no consensus has been reached on a definitive approach or solution.
There are references to potential issues with convergence and the use of calculators for evaluating integrals, which some participants suggest may not be appropriate for this type of problem. Additionally, there are mentions of specific values related to the integral, but these are not universally accepted within the discussion.
Susanne217
Hi I am working on a solution for the integral the integral
[tex]\int_{-\infty}^{\infty} (\frac{sin(x)}{x})^2 dx[/tex]
I know from theory that
[tex]\int_{-\infty}^{\infty} f(x) dx = \int_{-\infty}^{a} f(x) dx + \int_{-\infty}^{a} f(x) dx[/tex]
So that [tex]\int_{-\infty}^{1} (\frac{sin(x)}{x})^2 dx + \int_{1}^{\infty} (\frac{sin(x)}{x})^2 dx[/tex]
since [tex](\frac{sin(x)}{x})^2 = \frac{sin^{2} x}{x^2}[/tex]
and by trig identity
[tex]\frac{sin^{2} x}{x^2} = \frac{1-cos(2x)}{2} \cdot x^{-2}[/tex]
for clarity that gives me an integral that I need to solve where
[tex]\int_{-t}^{t} \frac{1-cos(2x)}{2x^2} dx = \int^{1}_{-t}\frac{1-cos(2x)}{2x^2} dx + \int^{t}_{1}\frac{1-cos(2x)}{2x^2} dx[/tex]
What I am simply am burning to know is that the correct approach?
I have read in another thread in this forum that the purpose of the task is to first find a corresponding taylor series expansion
so anyway since [tex]\frac{sin^2 x}{x^2} = \frac{1-cos(2x)}{2x^2} = \frac{-(cos(2))-1}{2}\cdot (x-1) - \frac{cos(2) - 4 \cdot sin(2) + 3}{2} \cdot (x-1)^2 + 2 \cdot (7 sin(2) -6) \cdot (x-1)^3 + \cdot + ?[/tex]
I used [tex]x_0 = 1[/tex] since there is hole x = 0
I think you have some good ideas, and some that might not work. For instance, I don't know which thread you're referring to about the taylor series expansion, but it sounds like a messy approach.
Now if you already know the value for [itex]\int_{0}^{\infty}\frac{\sin x}{x}\,dx,[/itex] then this is even easier to evaluate. But that approach is probably not what you want, but we can do something else.
First of all, the integrand is even, so by parity symmetry,
[tex]\int_{-\infty}^{\infty}\frac{\sin ^2 x}{x^2}\,dx = 2\int_{0}^{\infty}\frac{\sin ^2 x}{x^2}\,dx.[/tex]
Convergence is not really an issue, since we have the x^2 in the denominator. By the trig identity you wrote down, the integral becomes
[tex]\int_{0}^{\infty}\frac{1-cos(2x)}{x^2} \,dx.[/tex]
Now there is a standard trick for writing the term 1/x^2 as the integral of an exponential as follows:
[tex]\frac{1}{x^{2}}=\int_{0}^{\infty}te^{-tx}\,dt.[/tex]
This is easy to verify by basic calculus. We can then work with a double integral by writing
[tex]\int_{0}^{\infty}\frac{1-cos(2x)}{x^2} \,dx = \int_{0}^{\infty}\int_{0}^{\infty}te^{-tx}(1-\cos 2x)\,dt\,dx .[/tex]
What we want is to switch the order of integration (i.e. switching the places of dt and dx and integrate with respect to x). This is justified by Fubini's theorem and Tonelli's theorem. The rest is more antiderivative computation from basic calculus.
Note that the same approach can be used to determine the value of [itex]\int_{-\infty}^{\infty}\frac{\sin x}{x}\,dx,[/itex] but showing convergence is trickier. There is probably a way to evaluate your integral via Fourier transforms and working with distributions, but the approach I outlined is completely elementary.
Hi snipez and thank you for your answer,
So the trick is to work out that integral?
But if I try to work out the that integral I get undefined on my calculator. So what do I need to do here?
I can see that I can return it to the original integral. Is that what I need to do ?
Sincerely
Susanne
P.s. I know that according to parsevals identity that original integral [tex]\int_{0}^{\infty}\frac{sin^2 x}{x^2} = \frac{\pi}{2}[/tex] then our integral must be [tex]\frac{\pi}[/tex]?
Don't use a calculator for actual math problems.
After switching the order of integration, we have to evaluate
[tex] \int_{0}^{\infty}\frac{1-cos(2x)}{x^2} \,dx = \int_{0}^{\infty}\int_{0}^{\infty}te^{-tx} (1-\cos 2x)\,dx\,dt.[/tex]
In other words, we treat t as a constant and integrate with respect to x (inner integral first of course). If you're having trouble with integrating
[tex]te^{-tx} (1-\cos 2x)[/tex]
with respect to x (t constant), you could always ask for help or use wolfram's integrator as a last resort.
sorry
then I get [tex]\lim_{t \to \infty } \int_{0}^{t} \frac{e^{-xt}((cos(2x)\cdot t^2 -t^2 - sin(2x)t-4)}{t^2+4} dt = \pi[/tex] how is that?
No, sorry it was a latex error, the (1-cos(2x)) is not part of the exponential. Incidentally, the value of the integral you posed is [itex]\pi,[/itex] which is also what you get for [itex]\int_{-\infty}^{\infty}\frac{\sin x}{x}\,dx.[/itex] However, you do have to demonstrate the relationship between the two, which can be done via differentiation under the integral sign or I think even a simple integration by parts.
I have done it hopefully correctly in my previous post. Hopefully it was what you were thinking of :)
Um, it looks like you got the inner integral for the most part, except you are missing a factor of 2 on the sin(2x)t term. Then you should have
[tex]\int_{0}^{\infty}\int_{0}^{\infty}te^{-tx} (1-\cos 2x)\,dx\,dt = \int_{0}^{\infty}\left[ \frac{e^{-xt}((cos(2x)\cdot t^2 -t^2 - 2sin(2x)t-4)}{t^2+4} \,dt \right]_{x = 0}^{x = \infty}\,dt.[/tex]
As x goes off to infinity, that big expression vanishes. Evaluate the big expression at x = 0 (don't forget the negative sign), then manipulate the result to make use of [itex]\int \frac{1}{1+t^2}\,dt = \arctan t + C[/itex] and you should be done.
  • · Replies 105 ·
13K
  • · Replies 23 ·
