Is there such thing as a steam panel for generating energy?
  • Thread starter Thread starter Zirngibism
    Energy Steam
The discussion revolves around the concept of a "steam panel" for generating energy, exploring hypothetical technologies that could harness steam and temperature differences for power generation, similar to solar panels. Participants consider both theoretical and biological models, with a focus on energy generation mechanisms that do not rely on traditional mechanical methods like turbines.
  • One participant proposes a hypothetical steam panel that captures steam and utilizes the temperature difference to generate power, seeking a non-mechanical approach.
  • Another participant mentions thermoelectronic devices (TEDs) as existing technology but notes they are typically used in reverse, requiring a temperature difference to function effectively.
  • A challenge is raised regarding the need for a cold condensation plate to maintain the temperature difference necessary for energy generation from steam.
  • A biological model is suggested, where the difference in salinity between fluids could be used to generate energy, leveraging the heat transfer during condensation to facilitate evaporation and energy storage in distilled water.
  • Further clarification is sought on how distilled water could be considered a form of energy storage, with a focus on the energy released when mixing water of different salinities.
  • Proposals are made regarding the use of membranes to exploit salinity differences for electricity generation, with reference to natural processes in trees that utilize salinity gradients to draw water.
Participants express various ideas and models, with no consensus reached on the feasibility or effectiveness of the proposed steam panel concept or the biological energy generation method. Multiple competing views remain regarding the mechanisms and principles involved.
Participants highlight the importance of temperature differences and state changes in energy generation, as well as the complexities involved in utilizing salinity differences. There are unresolved questions about the practicality and efficiency of the proposed methods.
Zirngibism
Such thing as a "steam panel" for generating energy?
Hi,
Sort of a hypothetical question here, though I suspect there's some real-world technology like this.
I was wondering about a possible way to generate energy using a panel that would catch steam, and use the temperature difference between the steam side and the back side to generate power, but not mechanically like a turbine. More like a solar panel.
It doesn't need to be more efficient than the conventional means of turning steam into power. This is more of a hypothetical scenario. (I'm making science fiction concept art of artificial and/or natural "plants" that live on a geothermally active area and capture energy from steamy hot springs. The idea doesn't have to "work" in real life, but I want it to be grounded in reality.)
I have googled "thermovoltaic", but it seems as though that term means "heat generated as a result of electricity" instead of the other way around.
Here's some stuff I've found so far, but none of them are really quite what I'm looking for. I was hoping for something that would work more like a solar panel, only with a different kind of cell. It also seems as though almost everything I've found has to do with using the sun as the thermo source as part of a solar panel...
http://www.freepatentsonline.com/5959239.html (This sounds right, but I wish there was a diagram or something. A little too technical for me.)
http://www.livescience.com/technology/070216_heat_power.html (Probably the closest thing I've found to what I want...)
http://www.sciencedaily.com/releases/2007/06/070603225026.htm (interesting, but not what I'm looking for.)
http://www.ferrotec.com/products/thermal/powerGen/ (Doesn't describe the process, but at least I know that this type of thing exists and is used in industry.)
So, anyway, if you have any link to something I'm missing, or know of some key vocabulary term that I could use in my searches, or can explain the process more concisely than in some of those links, I'd appreciate it!
Zirngibism said:
Hi,
I was wondering about a possible way to generate energy using a panel that would catch steam, and use the temperature difference between the steam side and the back side to generate power, but not mechanically like a turbine...
Thermoelectronic devices (look for TEDs) do exist, but are mostly used in reverse. Pump enough electricity through a TED, and you can have a small refridgerator with no moving parts. (Or overclock the CPU in your computer. ;-)
However, there is a serious problem with your concept. You need a temperature difference to do work. There can be a huge amount of energy deposited by the condensation, but you need the condensation plate to stay "cold" for the condensation to happen.
A much better and more biologically oriented method would be to use the difference in salinity between the fluids in the plant and the condensed water. The plant could use the heat transfer during the condensation process to evaporate water from the sap (on the other side of the leaves). Now the plants can store the distilled water as a way of storing energy.
Awesome reply, thanks so much!
You helped me remember that indeed much of the energy put in and taken out of fluid is in changing its state, not it's temperature. Hadn't really taken into account the state change, as you pointed out.
Still something I'm unclear on about your biological model, though. What do you mean by storing distilled water as energy? Do you mean the heat energy in the distilled water, using that to make sugars and such?
Energy is released when you mix water of different salinity. This occurs where rivers (relatively salt free) flow into oceans. There have been several proposals to use this to generate electricity. Take a membrane or three that allow water to pass but not salt. Put salt water on one side, and fresh water on the other. The fresh water will be drawn through the membrane and the water level on the saline side will be higher. (For electricity, use the difference in water levels to drive a turbine.) A biological system though can use the salinity difference directly. It is (part of) how trees draw ground water and move it up to the leaves.
  • · Replies 29 ·
  • · Replies 30 ·
