How Do You Calculate the Second Vector in a Vector Displacement Problem?
  • Thread starter Thread starter singingblonde
    Displacement Vector
The forum discussion centers on calculating the second vector in a vector displacement problem involving two displacements: the first vector has a magnitude of 150 cm at an angle of 120 degrees, and the resultant vector has a magnitude of 140 cm at an angle of 35 degrees. To find the second vector, users must apply vector component addition principles. The discussion emphasizes the necessity of understanding both the resultant vector and one of the initial vectors to derive the unknown second vector accurately.
  • Vector Component Addition
  • Understanding of Resultant Vectors
  • Basic Trigonometry (sine and cosine functions)
  • Knowledge of Vector Angles and Magnitudes
  • Learn how to decompose vectors into their components using trigonometric functions.
  • Study the method for calculating resultant vectors from two known vectors.
  • Explore graphical methods for vector addition and subtraction.
  • Practice solving vector displacement problems with varying magnitudes and angles.
Students in physics or engineering courses, educators teaching vector analysis, and anyone interested in mastering vector displacement calculations.
singingblonde
A man pushing a mop across a floor causes the mop to undergo two displacements. The first has a magnitude of 150 cm and makes an angle of 120 degrees with the positive x axis. The resultant displacement has a magnitude of 140 cm and is directed at an angle of 35 degrees to the positive x axis. Find the magnitude and direction of the second displacement (second vector)
I realize that somehow, we know the resultant vector and one of the vectors and need to solve for the second vector. Because nothing is known about the second vector, I don't know how to go about that. I've been working on this problem all day and truly need some help.
Hi singingblonde.
Suppose for a moment that the problem was reversed: the two vectors were given (for example: 150 cm with an angle of 120 degrees with the x-axis, and 140 cm at an angle of 35 degrees to the x-axis) and you were asked to calculate the resultant vector. Would you know how to solve that?
  • · Replies 19 ·
