Baseball - (2D?) Kinematics - Projectile Motion
The problem involves a baseball being hit at a specific speed and angle, with a right fielder attempting to catch it at a certain height. The subject area pertains to 2D kinematics and projectile motion.
  • Mixed
  • Participants discuss the use of kinematic equations to analyze the motion of the baseball and the fielder. There are suggestions to resolve the initial velocity into its x and y components and to consider drawing a graph for better visualization. Some participants express confusion about the methods and concepts involved.
The discussion is ongoing, with various approaches being explored. Some participants have attempted calculations, while others are questioning the feasibility of the fielder's required speed. There is no explicit consensus on the best method to solve the problem.
Participants note a lack of familiarity with certain concepts, such as graphing the problem, and express urgency due to an impending homework deadline.
Rker
A batter hits a baseball at a speed of 45 m/sec at an angle of 50° above the horizontal. The right fielder, who is standing 300 m away from the batter, begins to run when he sees the bat hit the ball. If the fielder runs at a constant speed, what speed does he need to run in order to catch the ball at a height of 1 m above the ground? Can he make it?
P.S. The batter hits a grounder.
Not sure. I think this one is used.
Vfx = Vox + atx
Please help if you can. I've honestly worked on this problem for at least two hours, but I don't understand it.
I believe you have to use Xf=Xi+vt+0.5at^2 to solve
I asked someone else, and he said that I should draw an accurate graph of this problem. But, I wasn't taught how to do this in class. I think my professor just used trigonometry or the equation you suggested, semc. I'm confused...
I am not sure what your friend suggested about drawing a graph but i believe drawing the projectile might help. Firstly you have to know that this is a 2D question so the equation has a x and y component. Just resolve the initial velocity into the x and y component and use the equation and you should be able to get the answer.
Thanks, semc. My homework assignment is due in a few minutes, so I can't type all that I wrote, but I calculated that the fielder must run 13.56 m/sec to catch the ball, which isn't possible.
Does Usain Bolt play baseball? =D
