| Thread Closed |
Isometry from R to itself. |
Share Thread | Thread Tools |
| Sep21-09, 01:19 AM | #1 |
Find all isometries from the reals to itself. 2. Relevant equations Well what we're basically doing is trying to find functions f: R -> R such that for any x, y in R, the property |f(x) - f(y)| = |x-y| holds. 3. The attempt at a solution OK, so this shouldn't be too hard. It seems like you could just plug in 0 for one of the variables above and then you're basically done. But can't we prove differentiability as follows? [tex]|f'(y)| = \lim_{x \rightarrow y}\left|\frac{f(x) - f(y)}{x-y}\right| = \lim_{x \rightarrow y}\frac{|x-y|}{|x-y|} = 1.[/tex] This seems to immediately imply that the functions are defined by either i(x) = x + C or j(x) = - x + K for arbitrary real numbers C or K. Are there any holes I overlooked? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep21-09, 02:09 AM | #2 |
Well, the equation
[tex] \lim_{x \rightarrow y}\left|\frac{f(x) - f(y)}{x-y}\right| = 1. [/tex] doesn't actually imply [tex] \lim_{x \rightarrow y}\frac{f(x) - f(y)}{x-y} \in \{ 1, -1 \} [/tex] The best you can say is that the set of limit points of (f(x)-f(y))/(x-y) as x->y is a subset of {1, -1}. |
| Sep21-09, 09:54 AM | #3 |
Recognitions:
that would be true for continuous isometries
say f(x)=f(y)+(x-y)g(x,y) all we would know is |g|=1 we might have say g=-1 x rational g=1 x irrational |
| Sep21-09, 12:57 PM | #4 |
I understand your counterexample for noncontinuous isometries, but this one is lipschitz and hence uniformly continuous, so is there a way to extend the original argument?
*EDIT* The reason I pursued this approach in the original place is because I proved that [itex]|f(x) - f(y)| \leq (x-y)^2[/itex] for x,y in R implies that f is constant. In this case, you end up with |f'(y)| = 0, so we can just be rid of the absolute values and then recall the corollary to the mean value theorem. But it seems that I did not have to work with absolute values in the first place, since |a| = |b| implies that a = -b or a = b. However, I am aware of the concerns raised, so I am curious as to whether continuity - which we seem to have - can fix the original argument. Bah, upon closer examination of lurflurf's point, it doesn't matter whether f is continuous or not. Hmm well I think I have a better understanding of when to try something like this and when you can just substitute variables. Thanks. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Isometry from R to itself.
| isometry problem, pls help | Calculus & Beyond Homework | 1 | ||
| Isometry question. | Differential Geometry | 19 | ||
| Isometry and inverse | Calculus & Beyond Homework | 9 | ||
| Proof of Isometry | Calculus & Beyond Homework | 3 | ||
| Isometry | Calculus & Beyond Homework | 7 | ||
