Pumping electrons without magnetics?
  • Context: Undergrad
  • Thread starter Thread starter Brock
    Electrons Magnetics
The discussion explores the feasibility of moving electrons through a wire using mechanical pressure or heat. It examines various methods of electron movement, including thermoelectric effects and piezoelectric materials, and considers the implications of these methods in practical applications.
  • One participant proposes using mechanical pressure from a wheel or heat to push electrons down a wire.
  • Another participant mentions the Van de Graaff generator as a relevant example, noting it does not mechanically push electrons but uses an insulating belt to transport them.
  • A different participant argues that while heat can influence electron flow, it does not allow for "pumping" electrons in the implied sense, suggesting that thermocouples can generate electricity through temperature differences.
  • Discussion includes the use of semiconductor materials in Peltier junctions, which can generate power from heat and also operate in reverse to pump heat.
  • One participant introduces piezoelectric crystals, noting that they generate an electrical potential when compressed but do not function as traditional electron pumps.
  • Another participant clarifies that piezoelectric materials produce electrical potential rather than a continuous current, comparing their action to that of a bell rather than a pump.
  • There is a suggestion that combining a piezoelectric crystal with a diode could create an electron pump mechanism.
Participants express differing views on the effectiveness of using mechanical pressure and heat to move electrons, with some supporting the idea of thermoelectric effects while others challenge the notion of "pumping" electrons. There is no consensus on the best method for achieving electron movement.
Participants discuss various assumptions about the behavior of electrons in different materials and the conditions under which they might flow. The limitations of each proposed method and the specific properties of materials like thermocouples and piezoelectric crystals are noted but not resolved.
Brock
Is it possible to push electrons down a wire if a wheel applying pressure to the wire were rolled down it? Another way to cause the pressure would be to apply a heat source down the wire.
That's what the Van de Graaff high voltage generator does.
As for using pressure, no not really. As for heat, yes, but...
The electrons will flow slightly away from the hot point until the extra pressure due to the heat is offset by the electrical potential. You couldn't actually "pump" them along a wire in the sense you seem to imply.
However using wires of different metals in which the electrons respond to heat to different degrees (different Seeback coefficients) you can effectively make a heat engine. This is a thermocouple. The temperature difference will drive a current and you actually can generate electricity this way
You can get even more effect with semiconductor materials oppositely doped. This is known as a Peltier junction.
This is how the Voyager space-craft were powered. They travel too far from the sun to use solar cells. Using a plutonium pellet which generates heat as the plutonium decays and a thermoelectric generator, power is generated to operate the craft.
What is more this effect can work in reverse. Running a current through a Peltier junction causes heat to be pumped from one side to the other. These are how the little electronic refrigerators you plug into your car's cigarette lighter work. The are also used to cool the processor in some PC's.
Check out the wikipedia article:http://en.wikipedia.org/wiki/Thermoelectric_effect"
Not quite the same thing. The Van de Graaff generator doesn't mechanically push electrons along a conductor. Rather an insulating belt mechanically carries the electrons up the potential difference between base and top.
That's true, the belt is an insulator.
those crystals in lighters give off electrons when they're compressed. It should work with them no?
If so then all pumps, and turbines should be able to remake into electron pumps.
Those are piezoelectric crystals. They are different from conductors and what is happening is not the same as "squeezing out electrons" in the sense discussed earlier.
For one thing the main property of a piezoelectric material is that deforming them produces an electrical potential, not a current. This electrical potential can then pull electrons through conductors placed on the surface of the crystal.
The spark you see from the lighter is not electrons flowing one way but rather electrons being pulled back and forth as the crystal vibrates. The piezo crystal is acting more like a bell than a pump.
[edit: Let me however add that yes you could put a diode in the circuit with the piezo-crystal and together they would act as an electron pump. The crystal is kind of like a piston and the diode kind of like a valve.]
  • · Replies 20 ·
  • · Replies 36 ·
