Integrating Exponential Functions with Natural Logarithms
  • Thread starter Thread starter -EquinoX-
    Integrate
The discussion revolves around the integration of the function \((3x-5)e^{4\ln(x)}\), focusing on the manipulation of exponential and logarithmic expressions within the context of calculus.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore rewriting \(e^{4\ln(x)}\) and question the implications of logarithmic properties. Some suggest integrating components separately, while others express confusion about the order of operations and the treatment of the integral.
The conversation includes various interpretations of the integration process, with participants offering differing views on how to approach the problem. Some guidance has been provided regarding the manipulation of the exponential function, but no consensus has been reached on the final answer or the correctness of the approaches taken.
Participants mention an initial condition \(y(1) = 5\) and express frustration with an online homework system marking their answers as incorrect, indicating potential constraints in the problem setup or solution format.
-EquinoX-
[tex]\int (3x-5)e^{4ln(x)}[/tex]
Any ideas?
rewrite [tex]e^{4ln(x)}[/tex] as [tex]e^{(ln x)4}[/tex] and remember your rules for exponents!
does e^(ln(x)) becomes x?
yes.
http://img85.imageshack.us/img85/8667/questionl.th.jpg
If the original question is above and I solved the integral above which results in:
[tex]x^3 - \frac{5x^2}{2} + \frac{C}{e^{4ln(x)}[/tex]
then I need to divide this by [tex]e^{4ln(x)}[/tex] right??
I am also given an initial state of y(1) = 5
the final result that I get is :
2x^2-5x+13/x
why is this wrong? which step am I not doing it right?
however web assign marks it as wrong.. am I doing something wrong?
Apparently.
What's [tex]\int_0^x\frac{4}{t}dt[/tex]
Easy mate
integration of (3x-5) = 3x^2-5x
hence integration of e^4ln(x) is = e nd ln cancell each other log rules..
hence take 4 to the other side becomes power. = x^4
final ans
(3x^2 - 5x).(x^4)...so u can do the rest i assume.
hope been helpful
to -EquinoX
well [tex]e^{4ln(x)}[/tex] is equal to [tex]e^4x[/tex] right?
if that's so the the integration becomes [tex]e^4 \int (3x^2-5x)[/tex]
which is [tex](x^3 - \frac{5x^2}{2})e^4 + C[/tex]
is this correct?
if so then I divide [tex](x^3 - \frac{5x^2}{2})e^4 + C[/tex] by [tex]e^{4ln(x)}[/tex] and then simplifying that I get [tex](x^2 - \frac{5x}{2}) + \frac{C}{e^{4ln(x)}}[/tex]
[tex]e^{4 + ln x} = e^{4}e^{ln x} = e^{4}x[/tex]
[tex]e^{4ln x} = e^{(ln x)4} = (e^{ln x})^{4} = x^{4}[/tex]
I thought we already went over this. As to the integral question I asked earlier, what's ln 0?
shouldn't it be the integral of (3x-5)*x^4\
I am just confused why you integrate (3x-5) first and then e^4ln(x) separately... as I recall they were multiplied
I'm not doing that. I'm finding the integrating factor. That's how you got [tex]e^{4ln x}[/tex], right? By performing the integral I gave above?
okay so the integral should be [tex]\int 3x^5-5x^4 = \frac{x^6}{2} - x^5 + C[/tex] then divide all of this by [tex]x^4[/tex] (integrating factor) I will get [tex]\frac{x^2}{2} - x + \frac{C}{x^4}[/tex]
put in the initial condition which is y(1) = 5,. I can solve for C which is 11/2 then plug it back in I will have [tex]y = \frac{x^2}{2} - x + \frac{11}{2x^4}[/tex] as a particular solution, true or not?
Yes, but in the future, once you have the solution, you can always check it for yourself.
and once again reason why I post it is because web assign doesn't accept that answer, I re did the problem couple of times and it goes down to that answer... I hate this thing
That's harsh. I hated those things when I had to do them. It's right though. I plugged in for 1 and plugged the solution into the ODE you gave. They're both right so it's not your fault. Maybe put it all in one fraction or something.
okay...I'll see what I can do...
  • · Replies 19 ·
