What is the temperature and pressure relationship during the pump down process?
The discussion revolves around the relationship between temperature and pressure during the pump down process of a vacuum chamber. Participants explore both adiabatic and isothermal conditions while attempting to derive equations that describe these relationships over time. The focus is on applying the ideal gas law and energy balances to understand how these variables interact as the chamber is evacuated.
  • One participant describes the initial conditions of a vacuum chamber and seeks to calculate temperature and pressure as functions of time under adiabatic and isothermal assumptions.
  • Another participant suggests applying the ideal gas law to relate pressure and temperature, questioning whether it has been utilized in the calculations.
  • Multiple participants engage in deriving equations from energy balances, discussing the implications of holding volume constant and the challenges of relating pressure and temperature without additional known variables.
  • There is a discussion about the nature of volumetric flow rates, with some participants asserting that while volumetric flow is constant, the molar flow rate changes as the chamber is evacuated.
  • One participant proposes equating the molar flow rate derived from the ideal gas law with that from the volumetric flow rate to solve for pressure as a function of time.
  • A later reply introduces a key relationship involving the volumetric pumping speed and the number of moles, which helps in progressing the calculations.
Participants express differing views on how to approach the problem, particularly regarding the treatment of flow rates and the application of the ideal gas law. While some progress towards a solution, there is no consensus on the best method to derive the relationships between temperature and pressure during the pump down process.
Participants note limitations in their equations due to the changing nature of the gas flow and the assumptions made about the system's conditions. There are unresolved mathematical steps and dependencies on specific definitions that affect the clarity of the discussion.
leumas614
Can anyone please help me with this problem?
Consider the act of evacuating a chamber with a vacuum pump. Vacuum pumping rates are usually given in volumetric pumping speeds, Sp, whose units are typically volume/unit time, e.g., 1 m3/min. In other words, the number of molecules in 1 m3 at the chamber pressure and temperature are removed in one minute. A 0.1 m3 chamber is initially at atmospheric pressure (1 bar) and 298 K. The gas may be considered to be an ideal diatomic gas. Calculate and plot the temperature and pressure in the chamber as a function of time with a pump rated at Sp= 1 m3/min if the pump down process may be considered to be
(a) adiabatic
(b) isothermal.
I've done everything I can think of with energy and entropy balances. I think the problem is the temperature and pressure of the influx stream are changing as the chamber is evacuated so I don't know how to relate them to time. I need an equation for Temperature as a function of time and nothing else and the rest is easy.
I think dn/dt is the Sp but in units of mol/min with Volume held constant. Now I just need to know T without relying on P (or vice versa)
Thanks.
Have you applied the ideal gas law yet? It's not clear from your post.
Yes, I took the time derivative of [tex]PV=nRT[/tex] holding V constant.
[tex]V \left(\frac{dP}{dt}\right)=R\left(T \frac{dn}{dt}+n \frac{dT}{dt}\right)[/tex]
dU=nCvdT
[tex]\frac{dU}{dt}=Cv\left(n\frac{dT}{dt}+T\frac{dn}{dt}\right)[/tex]
from energy balance, dU=Hdn integrating gets U=Hn which equals U=(U+PV)n
Nothing else seems to work. Intuitively I would think the pressure would decrease non-linearly but I see no way of introducing that into the equations.
OK, let's apply the energy differential equation to the adiabatic case. Take the system to be the amount of gas that doesn't leave the box. What can you say about [itex]dU[/itex]?
You get
[tex]Cv\frac{V}{R}\frac{dP}{dt}=\frac{dU}{dt}[/tex]
So we can relate U with P but you still don't have an expression for P so only one equation with two unknowns. You can't replace P with an expression for T because T is also unknown.
Here's what I did.
[tex]dU=d(Hn)[/tex] but both H and n are not constant so
[tex]\frac{dU}{dt}=H\frac{dn}{dt}+n\frac{dH}{dt}[/tex]
[tex]\frac{dU}{dt}=\left(U+PV\right)\frac{dn}{dt}+n\left(\frac{dU}{dt}+\frac{dP}{dt}V\right)[/tex]
Through some algebra:
[tex]\frac{dU}{dt}(1-n)-U\frac{dn}{dt}=PV\frac{dn}{dt}+\frac{dP}{dt}nV[/tex]
V and [tex]\frac{dn}{dt}[/tex] are given. I think the [tex]n[/tex] in this case is the total number of moles you start out with so that is known from [tex]PV=nRT[/tex]. Now I have two first order ODE that I can't solve.
I was thinking more like, the rate of work that that amount of gas does is [itex]P(dV/dt)[/itex], which is [itex]PF[/itex] where [itex]F[/itex] is the volumetric flow rate.
It was easier for me to start with the isothermal case. What's [itex]dn/dt[/itex], where [itex]n=PV/RT[/itex]? What's [itex]dn/dt[/itex] in terms of the volumetric flow rate? Set these equal and integrate to solve for pressure.
But this is what I don't understand. The volumetric flow rate is not constant because the tank is draining so presumably the amount of molecules flowing out of the tank is changing with time. So I don't know what the volumetric flow rate is. I understood the Sp in the question to mean, it takes 1 minute to evacuate a 1 m3 chamber so it would take a tenth of that time to evacuate a 0.1 m3 chamber.
The volumetric flow rate is constant, but the molar flow rate is not constant. A better way to think of it is that 17% of the chamber's contents are removed every second. Employing the continuum assumption, the chamber is never completely emptied.
I still don't quite follow what you're suggesting. The volume does not change because we took the system to be the inside of the chamber which is rigid. Using [tex]dV/dt[/tex] would only work if the chamber was not rigid. But then if the volumetric flow rate is not the molar flow rate than it has no place in any equation and that wouldn't make sense.
[tex]n=\frac{PV}{RT}[/tex]
[tex]\frac{dn}{dt}=\frac{1}{RT}\left(V\frac{dP}{dt}+P\frac{dV}{dt}\right)[/tex]
And the rate of work can't be [tex]P\dot{V}[/tex] because pressure is not constant.
OK, let's back up a second. For the isothermal case, I'm suggesting you consider the system to be the chamber, determine [itex]dn/dt[/itex] by the ideal gas law (which you did in your last post, [itex](V/RT)(dP/dt)[/itex]), and equate that to [itex]dn/dt[/itex] determined by the volumetric flow rate [itex]F=dV_0/dt[/itex]. You can use the ideal gas law to get this molar flow rate because the gas removed has a constant volume and follows the ideal gas law. Set these two molar flow rates equal and solve for [itex]P[/itex] as a function of time.
For the adiabatic case, I'm suggesting you take the system to be the amount of gas that stays in the chamber as it pushes out an infinitesimal amount of gas during evacuation. This system is adiabatic and does work on the exiting gas, so its energy decreases, and the rate of energy decrease is [itex]P\,dV_0/dt[/itex]. Stick in the relationship between specific heat and energy and continue from there.
ok, I got it.
I asked the TA and he said the key relationship that I was missing is this:
[tex]\frac{dn}{dt}=n\frac{Sp}{V}[/tex] The units work out.
So I worked it out from there. What you can do then is say [tex]U=H_{out}n_{out}[/tex] since [tex]H_{in}n_{in}[/tex] is zero because there is no mass flowing into chamber.
Then you can say dU is nCvdT so dU/dt is same as above post. Equate [tex]nCvdT[/tex] with [tex]H_{out}n_{out}[/tex]n (you can replace H with U+RT) and you take it from there. I worked it out and basically you get a P=noRTo/V times an exponential e.
  • · Replies 116 ·
