Can someone explain/show how to set this problem up
  • Thread starter Thread starter Ion1776
    Set
To determine how far the hamster runs in its wheel, first calculate the circumference using the formula C = 2πr, where r is the radius of 6.8 cm, resulting in a circumference of approximately 42.7 cm. The hamster runs for 3.1 hours, which equals 11,160 seconds. With an angular velocity of 3.0 radians per second, the hamster completes about 0.477 turns per second. To find the total distance, multiply the number of turns by the circumference, leading to a final distance of approximately 1,000 meters run in one night. Understanding the relationship between angular velocity, time, and distance is crucial for solving this problem.
Ion1776
A hamster runs in its wheel for 3.1 hours every night. If the wheel has a 6.8 cm radius and its average angular velocity is 3.0 radians per second, how far does the hamster run in one night?
I would convert that 3 radians into a number of turns. I think a full turn is 2*pi radians, so it is about half a turn per second. How far does the hamster go in a turn?
So, 3.0/2pi=.4774648
3.1 hours * 3600secs=11160 Secs
Now what to do with the radius, and what equation to use
thanks
Not quite, look at your units. He runs at 3rads/s and the entire circle is 2pi rads. You want to find the time it takes to go through the entire circle. Once you find that you need to find how far one complete turn is. The hamster travels the circumference of the circle each revolution. How far is that?
