Question about current in an infinite circuit
The discussion revolves around the behavior of current in an infinite circuit containing only a wire and an electromotive force (emf). Participants explore the implications of circuit size on current flow, particularly in non-stationary conditions, and the applicability of Kirchhoff's laws versus Maxwell's laws in such scenarios.
  • One participant questions whether the current would be uniform throughout a very large circuit or if it would be null at large distances initially, suggesting that near the emf, the current could theoretically be infinite due to the absence of resistance.
  • Another participant argues that in reality, all generators have internal resistance, and no wire is entirely without resistance, implying that infinite currents cannot occur.
  • A suggestion is made to look into "transmission line" theory as a relevant concept for understanding the behavior of current in large circuits.
  • It is noted that Kirchhoff's laws are approximations to Maxwell's laws, and the small circuit approximation fails for very large circuits, necessitating the use of Maxwell's laws instead.
  • A participant provides a technical detail regarding the impedance of a coaxial transmission line and how it behaves as the dimensions change, particularly in relation to a bare wire.
Participants express differing views on the applicability of Kirchhoff's laws in large circuits, with some agreeing that these laws are approximations that break down under certain conditions, while others emphasize the practical limitations of real-world components like resistance. The discussion remains unresolved regarding the initial behavior of current in an infinite circuit.
The discussion includes assumptions about ideal conditions (e.g., a wire with no resistance) and acknowledges the limitations of circuit theory when applied to very large systems.
fluidistic
I've asked myself the following question but couldn't think about an answer.
Imagine a hypothetical situation : you have a very large (more than [tex]10^{10}m[/tex]) circuit that contains only a wire (with no resistor) and an emf. Now you turn on the emf... will the current be the same in the whole circuit? Or will the current be null at very a large distance initially while close the emf the current would be theoretically infinite since there's no resistor?
So that you can't apply Kirchhoff's current law in very large circuits when the situation is not yet stationary.
Equivalently one can imagine a situation of a human size circuit but with very small time (less than say [tex]10^{-12}s[/tex]).
I'd like to know what really happens, just to understand better how the universe really work, it's not a homework question.
Thanks.
well, reality is a totally different animal. a REAL generator will have an internal resistance, no wire will have no resistance at all, though for a small circuit it could be negligible compared to that of resistors, so you will have no infinite currents. And since now your system does have a resistance the problem is quite easily solved.
look for "transmission line"
This is correct. Kirchoff's laws and the rest of the circuit theory are all approximations to Maxwell's laws. One of the assumptions is the so-called "small circuit approximation" which basically says that the circuit is small compared to the wavelengths involved so that all parts of a wire can be assumed to be at the same potential. Obviously the small circuit approximation is violated for very large circuits and then you have to use Maxwell's laws.
Ok thanks I will look at it in details but I think they are not large enough.
Thank you very much, I'm done with this.
Hi Fluidistic-
For a bare wire in vacuum (no dielectric) the signal velocity is the speed of light. The impedance of a coaxial transmission line with an air dielectric is
Z = (377/2 pi) Ln (b/a)
where b= radius of outer conductor and a is radius of inner conductor. When b/a becomes very large (like for a bare wire), the impedance gets very large logarithmically.
Bob S
17K
  • · Replies 30 ·
