Limit of an unknown constant expression
  • Thread starter Thread starter chaslltt
    Constants Limit
The limit of the expression as x approaches infinity, specifically sqrt(x^2 + ax) - sqrt(x^2 + bx), can be simplified by factoring out x from the square roots. The resulting expression is (ax - bx) / (sqrt(x^2(1 + a/x)) + sqrt(x^2(1 + b/x))). This simplification allows for the cancellation of x terms, leading to a solvable limit. The conclusion is that the limit can be determined despite the unknown constants a and b.
  • Understanding of limits in calculus
  • Familiarity with square root properties
  • Knowledge of algebraic manipulation techniques
  • Basic concepts of infinity in mathematical analysis
  • Study the concept of limits involving infinity in calculus
  • Learn about L'Hôpital's Rule for indeterminate forms
  • Explore algebraic techniques for simplifying expressions with square roots
  • Investigate the behavior of functions as they approach infinity
Students studying calculus, particularly those tackling limits and indeterminate forms, as well as educators seeking to clarify concepts related to limits involving square roots.
chaslltt
find limit of x as it approaches infinite sqrt(x^2+ax)-sqrt(x^2+bx)
a and b are not given
Looking at this equation I first eliminated the square roots. After simplifying i ended up with ax-bx/sqrt(x^2+ax)+sqrt(x^2+bx) I think that this problem cannot be solved b/c a and b are not given. Is this right or is there another way of solving this?
You can't have ax-bx because that basically turns out to be ∞-∞. So you need to pull out x from the square roots so you can cancel out the x's in the numerator.
[tex]\frac{ax - bx}{\sqrt{x^2 + ax} + \sqrt{x^2 + bx}} = \frac{ax - bx}{\sqrt{x^2(1 + \frac{ax}{x^2})} + \sqrt{x^2(1 + \frac{bx}{x^2})}} = \frac{ax - bx}{x\sqrt{1 + \frac{a}{x}} + x\sqrt{1 + \frac{b}{x}}}[/tex]
See where you can go from there.
thank you
  • · Replies 18 ·
