Thread Closed
Maximum acceleration of a car
Share Thread Thread Tools
Sep28-09, 05:55 PM   #1
What is the maximum acceleration a car can undergo if the coefficient of static friction between the tires and the ground is 0.38?
that is it, no mass or anything else
2. Relevant equations
F=ma
(friction coefficient)Fn=Ffr
Fn = normal force
Ffr = friction force
3. The attempt at a solution
I have tried different things, but I can't figure out how to do the problem without a mass...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep28-09, 08:42 PM   #2
Recognitions:
Homework Helper Homework Help
Show your calculations.
The car will start moving when the applied force overcomes the frictional force.
Sep28-09, 09:00 PM   #3
AEM
Recognitions:
Gold Membership Gold Member
Quote by Hailcanadien View Post
[b]1.
The fact that no mass is given should be a clue. In other words you can expect that the mass of the car will cancel from the equation you want to develop.
The previous hint was not quite correct. In essence you can think of the car being the car is accelerated by any force less than, or just equal to the static frictional force between the tires and the road. Above that and the tires will spin causing rubber to be burned and the car accelerates more slowly.
Hence you need to combine F = ma and your equation for the frictional force. Remember that the frictional force is given by the coefficient of static friction times the normal force. What is the normal force? There you will find a mass that will cancel the m in F = ma.
Thread Closed
Tags
acceleration, coefficient, force, friction, maximum
Thread Tools
Similar Threads for: Maximum acceleration of a car
Thread Forum Replies
Finding maximum acceleration with COF of Ms Introductory Physics Homework 9
finding maximum speed, maximum acceleration, and maximum resisting force for pendulum Advanced Physics Homework 8
How to find the maximum velocity and maximum acceleration? Introductory Physics Homework 5
Maximum acceleration. General Physics 34
