DC-DC conversion from ca. 10V to 1000V
  • Thread starter Thread starter flos
To achieve a DC voltage conversion from 12V to 1000V, utilizing a boost converter or buck converter in conjunction with a transformer is essential. A transformer with a 1:1000 ratio can be employed in a buck configuration to achieve 12000V, while a 1:100 ratio in a boost configuration can yield 1200V. IXYS rectifiers are recommended for mid/high power applications, and using three 1kV diodes in series on the secondary winding can effectively manage back-EMF while charging a capacitor to reach the desired voltage.
  • Understanding of boost and buck converter configurations
  • Knowledge of transformer ratios and their applications
  • Familiarity with high-voltage rectifiers, specifically IXYS products
  • Basic electronics skills, including working with capacitors and diodes
  • Research transformer design and sourcing for high-voltage applications
  • Learn about the specifications and applications of IXYS rectifiers
  • Study the principles of back-EMF and its management in high-voltage circuits
  • Explore practical examples of boost and buck converter implementations
Electrical engineers, hobbyists working on high-voltage projects, and anyone involved in designing or implementing DC-DC conversion systems.
flos
Hello All,
For doing electrostatic clamping I need a high voltage. My source delivers 12V DC but I need 1000V. How to do this :confused: ?
I know about Boost Converters but all information I find goes up to 400V maximum. Are there special things to take into account when going up to 1000V?
Thanks in advance, Ciao.
Flos
idea
The boost converter concept is right on... or a buck... either way, you're probably going to need a transformer to step up the voltage first.
A 1:1000 transformer/transformer cascade (in a buck configuration) would give you 12000V, then your duty cycle would be in a reasonable range (about 83%). Dbuck = Vout/Vsecondary
..or a 1:100 transformer/transformer cascade (in a boost configuration) would give you 1200V, so D=88%. Dboost=1-Vsecondary/Vout
Try IXYS for your rectifiers; they have a pretty good selection of mid/high power applications like yours. As for transformers... ther are many vendors, and if you don't find what you are after, there are houses out there that will custom build one for you.
A lot will depend on the current needs of the intended load and the current limitations of your 12V supply.
Just get a 120v-12v power transformer.
Wire a mechanical doorbell buzzer in series with the low-voltage winding.
Hook up THREE 1kv diodes in series on the secondary winding so that ONLY BACK-EMF can pass. Charge your capacitor with that output.
You'll get your 1000v with no other parts being needed.
I have one of these wired together and long-since misplaced somewhere in the shop.
  • · Replies 68 ·
16K
