what is Tubes Assembly and Manifold for engines?
by SeanNg
Tags: assembly, engines, manifold, tubes
SeanNg
SeanNg is offline
#1
Sep28-09, 11:05 PM
P: 8
Dear all,
I am so sorry for my stupid questions. Currently, I am looking for documents (lecture notes) on tubes assembly and manifold for aircraft engine.
What are those tubes assembly and manifold? What are those characteristic? I did quite alot google search, however, I only found any good sketch/picture representation of these tubes and manifold. I would like to know their functions in the aircraft engine and why I saw many of them made of aluminum alloy but some of them does not have materials specification?
I am doing my third year study in Engineering!
Thank you very one for reading.
Sean
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
SeanNg
SeanNg is offline
#2
Sep30-09, 11:44 PM
P: 8
Somebody helps?please!
Cyrus
Cyrus is offline
#3
Sep30-09, 11:59 PM
Cyrus's Avatar
P: 4,780
I don't understand your question. You might have better luck retyping it.
SeanNg
SeanNg is offline
#4
Oct5-09, 04:13 AM
P: 8
Hi Cyrus,
I am so sorry for my bad English. Do you know about the works of repairing Tube Assembly and Manifolds in Aircraft engines? I would like to know the natures of these jobs?
Thanks in advanced!
pitts
pitts is offline
#5
Oct13-09, 11:25 PM
P: 11
Tube assembly?? I am assuming by manifold you mean the aircraft sump. The manifold is on the other side of the carburetor or fuel servo if fuel injected. The intake tubes disperse the air fuel mixture from the manifold to each cylinder.The engine oil is also in the sump. They run intake air through the sump around the oil to help cool it. Intake air is basically ram air when in flight.
SeanNg
SeanNg is offline
#6
Oct14-09, 09:34 AM
P: 8
Hi Pitts,
In fact, I am not very sure about the tube assembly work scope. I would do more research on that. Thank you very much and have a nice day..
pitts
pitts is offline
#7
Oct14-09, 07:26 PM
P: 11
I forgot to ask Piston driven or turbine??
SeanNg
SeanNg is offline
#8
Oct14-09, 09:11 PM
P: 8
It should be Turbine. The PW4000 series..
Register to reply
Related Discussions
small engines vs. big engines? General Engineering 75
Sectioning assembly Engineering, Comp Sci, & Technology Homework 0
C++ to Assembly Programming & Computer Science 4
help in assembly Programming & Computer Science 6
begin to use assembly without any programming knowledge Electrical Engineering 1
