| Thread Closed |
How are satellites cooled? |
Share Thread | Thread Tools |
| Sep29-09, 03:07 AM | #1 |
For example, most satellites will have CPU processors. On land, they require a heat-sink to transfer the energy to the air quickly so the CPU reaches ambient temperatures. But on a satellite there is no significant mass to absorb the generated heat from processing. So how are satellites kept cool?
Thanks |
| Sep29-09, 07:14 AM | #2 |
Recognitions:
I'm not 100% positive, but I would guess the same way the sun transfers heat to us.
| Sep29-09, 07:46 AM | #3 |
Admin
There are three methods of heat transfer, but only one can be used in vacuum.
| Sep29-09, 08:07 AM | #4 |
Mentor
Short answer: The spacecraft is a heat sink for the electronics.
So how is the spacecraft's temperature maintained? That is the subject of spacecraft thermal control. A full answer would require writing a book. Here is the first chapter of *the* book on the subject, Spacecraft Thermal Control Handbook: http://www.aero.org/publications/gilmore/gilmore-1.html. Here is a presentation on the issue of spacecraft thermal control: http://www.ieec.fcr.es/english/forma...esentation.pdf. The European Space Agency has a good site on spacecraft thermal control, http://mechanical-engineering.esa.int/thermal/. |
| Oct13-09, 11:30 PM | #5 |
I'm a pilot and I have an open cockpit aircraft. It is really cold at 5000ft msl. If its 80 degrees farenheit on the ground it's 40 degrees or so minus the wind chill. So its about zero. I would say in space it's probably a lot colder than that. I think the necessary question is how does a satellite keep from freezing???
| Oct13-09, 11:43 PM | #6 |
| Oct13-09, 11:58 PM | #7 |
Recognitions:
Theres a lot of work in building lower power FPGAs to reduce the amount of CPU you need. |
| Oct14-09, 12:49 AM | #8 |
So your saying that even though its freezing up there the heat will stay in the same spot??? Not transfer to cool. Then how do comets collect ice?? Or why are they mostly ice. Why is there ice in space? Are you saying the matter that formed the ice was ice before it entered space?? Or do comets have an atmosphere??
| Oct14-09, 03:31 AM | #9 |
Admin
| Oct14-09, 07:16 PM | #10 |
Excuse my ignorance. I just didn't understand the heat dissipation part. The heat dissipates at a much slower rate than in atmospheric conditions. So it is tricky to remove the produced heat before it becomes to hot and burns out......
| Oct14-09, 07:21 PM | #11 |
Also: while in direct sunlight, objects in space get very hot. The sun is an excellent source of heat radiation. Astronauts' suits are designed as much to cool them as to heat them. |
| Oct14-09, 07:30 PM | #12 |
| Oct15-09, 02:30 AM | #13 |
Admin
-- buffer calculator, concentration calculator pH calculator, stoichiometry calculator |
| Oct15-09, 08:59 AM | #14 |
| Oct15-09, 10:52 AM | #15 |
Admin
Right, haven't thought about it this way.
English difficulte langauge
| Oct15-09, 11:49 AM | #16 |
Recognitions:
Rust is still a problem.
In vacuum, especially with repeated heating and cooling, all sorts of volatiles boil out of the plastics, lubricants, cleaning residues etc. these get zapped into free radicals by the UV and deposit themselves on the coldest part of the payload - which is always either the detector or the window into the detector. Because of the rarefied atmosphere, UV radiation and mix of reactants you get some weird chemical reactions that you never thought of in a lab. And they aways coat or attack the most sensitive bit of kit. |
| Oct21-09, 12:15 PM | #17 |
I would think the processors are not so important for heat as the CCDs on satellites used to take pictures, which need to be kept so cold that thermal excitations are kept small so the pixels are less likely to falsely report an incident photon. Is there much need for processing power on a spacecraft, apart from sending the signals back to Earth? How hot do they get when fully operating, and surely this wouldn't damage a chip in 2.7 K surroundings!?
Apart from that all they can do is shield the equipment from the heat (and wind) of the sun with the rest of the satellite body, or, do like WMAP does and live in constant shadow eclipsed by the Earth at L2, I guess they can just add metal conducting stiprs to conduct excess heat away to be radiated faster? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How are satellites cooled?
| charge air cooled engines | Mechanical Engineering | 1 | ||
| Cooled by breeze | General Physics | 4 | ||
| Getting cooled by evaporation | General Physics | 26 | ||
| Water Cooled Stage | Mechanical Engineering | 9 | ||
| Water Cooled PC and Condensation... | General Physics | 2 | ||
