How Does Loop Size Affect Magnetic Flux in a Solenoid Setup?
The discussion focuses on calculating the magnetic flux through a square loop placed in a solenoid's magnetic field. The solenoid has 1350 turns per meter, a diameter of 5.55 cm, and carries a current of 2.20 A. The magnetic field (B) is determined using the formula B = μ₀*(N/L)*I, where μ₀ = 4π * 10^{-7} T*m/A. The magnetic flux (Φ) is calculated as Φ = B*A*Cosθ, with A being the area of the loop expressed as L² for different values of L, specifically 2.35 cm, 5.55×10−2 cm, and 12.5 cm.
  • Understanding of magnetic fields and solenoids
  • Familiarity with the formula for magnetic flux
  • Knowledge of basic geometry for calculating area
  • Ability to manipulate algebraic expressions
  • Calculate magnetic flux for varying loop sizes in a solenoid setup
  • Explore the effects of solenoid current on magnetic field strength
  • Investigate the relationship between loop orientation and magnetic flux
  • Learn about the applications of magnetic flux in electromagnetic devices
Students studying electromagnetism, physics educators, and anyone interested in the practical applications of magnetic fields in solenoid configurations.
spriter
A single-turn square loop of side L is centered on the axis of a long solenoid. In addition, the plane of the square loop is perpendicular to the axis of the solenoid. The solenoid has 1350 turns per meter and a diameter of 5.55 cm, and carries a current of 2.20A
Magnetic Field (B) of a solenoid: B = [tex]\mu_{0}[/tex]*(N/L)*I
Where [tex]\mu_{0} = 4pi * 10^{-7} T*m/A[/tex] , N/L is loops per unit length, and I is current
[tex]\Phi = B*A*Cos\theta[/tex]
I tried doing this: I use the Magnetic Field of a solenoid formula to find the magnetic field through the solenoid - because I know the magnetic field within the axis of the solenoid is constant, I thought I could just find the value of that constant B and then find the flux using the other formula for the different values of L (area) - and for areas larger than the circle of the solenoid - I could take the area of the flux as the area of the circle.
However, when I put my answer in, it tells me that the answer must be expressed in terms of L (I don't know if that's supposed to be the side length of the square or if it's supposed to be the length of the solenoid).Thanks.
Take the area of the loop as L^2 and find the flux through it.
Oh, sorry: I forgot a bit of information:
There are three parts to the question:
A) Find the magnetic flux through the loop when L = 2.35 cm.
B) Find the magnetic flux through the loop when L = 5.55×10−2 cm
C) Find the magnetic flux through the loop when L = 12.5 cm
That's what I was getting confused about, since it gives you L - why is it asking you to put it in terms of L - or does it mean put it in terms of the length of the solenoid?
Thanks
