Solving Definite Integral with Inverse Hyperbolic Identities
The discussion revolves around solving a definite integral involving inverse hyperbolic identities, specifically the integral of \(\sqrt{4x^2 - 1}\) from \(\frac{1}{2}\) to \(\frac{13}{10}\). Participants explore various methods of integration and seek to derive the exact solution.
  • Homework-related
  • Oscar presents the integral and expresses difficulty in using inverse hyperbolic identities to solve it.
  • One participant suggests using the identity \( \cosh^2(x) - \sinh^2(x) = 1 \) and proposes the substitution \( 2x = \tanh(y) \).
  • Another participant recommends the substitution \( x = \frac{1}{2} \cosh(y) \) and provides the transformed integral in terms of \( y \).
  • A later reply outlines the anti-derivative of \( \sinh^2(y) \) and provides a specific evaluation of the integral using the limits derived from the substitution.
  • One participant offers an alternative method to derive the anti-derivative of \( \sinh^2(y) \) using its definition.
  • Oscar confirms that he arrived at the same answer as another participant but through a different method.
Participants generally agree on the methods and arrive at the same solution, though they utilize different approaches. There is no explicit disagreement noted, but multiple methods are presented.
Some assumptions regarding the use of hyperbolic identities and the transformations applied may not be fully explored, and the discussion does not resolve all potential nuances in the integration process.
Readers interested in integration techniques, particularly those involving hyperbolic functions and definite integrals, may find this discussion beneficial.
2^Oscar
Hey guys,
I was doing some practice questions and this particular one has me stumped. The topic was on integration with inverse hyperbolic identities, and I was asked to give exact solutions for the following integral:
[tex]\int\sqrt{4x^2 -1} dx[/tex] between [tex]\frac{1}{2}[/tex] and [tex]\frac{13}{10}[/tex]
From looking around on the internet I have found a standard integral that I can use (http://en.wikipedia.org/wiki/List_of_integrals_of_irrational_functions" ) but I would quite like to know the process of deriving this.
I have been fairly confident with these questions but I can see no way of using the basic inverse hyperbolic identities to reach this result and express the definite integral exactly.
Could anyone please lend a hand?
Thanks in advance,
Oscar
Well, this is, after all, in a section about hyperbolic functions! I remember that [itex]cosh^2(x)- sinh^2(x)= 1[/itex] so that (dividing through by [itex]cosh^2(x)[/itex]) [itex]1- tanh^2(x)= sech^2(x)[/itex]. I would try the substitution [itex]2x= tanh(x)[/itex].
Write
[tex]x = \frac{1}{2} \cosh y[/tex]
Then
[tex]dx = \frac{1}{2} \sinh y dy[/tex]
The indefinite integral then becomes
[tex]\frac{1}{2} \int \sqrt{\cosh^2 y - 1} \sinh y dy[/tex]
You should then be able to find the indefinite integral of this if you use
[tex]\cosh^2 y - \sinh^2 y = 1[/tex]
and the definition of [tex]\sinh y[/tex]. After you do that, it's pretty easy to rewrite the answer in terms of x instead of y, and plug in the endpoints in terms of x.
Hey,
Thank you for your replies.
Solved the problem now :)
Thanks,
Oscar
Well, your integral is therefore:
[tex]\frac{1}{2}\int_{0}^{cosh^{-1}(\frac{13}{5})}sinh^{2}ydy[/tex]
We have the following anti-derivative:
[tex]\int\sinh^{2}{y}dy=\frac{1}{2}(\cosh(y)\sinh(y)-y)[/tex]
Using this, we get:
[tex] \frac{1}{2}\int_{0}^{cosh^{-1}(\frac{13}{5})}sinh^{2}ydy=\frac{1}{4}(\frac{156}{25}-cosh^{-1}(\frac{13}{5})[/tex]
Since [tex]cosh^{-1}(x)=\ln(x+\sqrt{x^{2}-1})[/tex], the answer can be simplified to:
[tex]\frac{39}{25}-\frac{\ln(5)}{4}[/tex]
By the way, if you want to see WHY we have the indicated anti-derivative, then use the definition of sinh:
[tex]\int \sinh^2 y dy = \frac{1}{4} \int (e^y - e^{-y})^2 dy[/tex]
and work from there.
thank you again for the speedy replies :)
I got the same answer as you, arildno, however I did it using different method...
Oscar
  • · Replies 27 ·
