Electrostatics: spherical shell
The discussion focuses on determining the electrostatic field and potential of a point charge \( Q_1 \) located at the center of a spherical conducting shell with inner radius \( a \) and outer radius \( b \), which carries a total charge \( Q_2 \). Using Gauss's law, it is established that the charge on the inner surface \( Q_a \) equals \(-Q_1\), while the charge on the outer surface \( Q_b \) is \( Q_1 + Q_2 \). The electric field inside the conductor is confirmed to be zero, and the total electric field is derived from the contributions of each charge.
  • Understanding of Gauss's law in electrostatics
  • Familiarity with electric field equations from point and surface charges
  • Knowledge of spherical symmetry in electrostatic problems
  • Basic concepts of electric potential and charge distribution
  • Study the application of Gauss's law in various geometries
  • Learn about electric field calculations for non-uniform charge distributions
  • Explore the concept of electric potential in electrostatics
  • Investigate the behavior of conductors in electrostatic equilibrium
Students and professionals in physics, particularly those focusing on electrostatics, electrical engineering, and anyone studying the behavior of electric fields in conductive materials.
Bapelsin
Electrostatics: spherical shell [SOLVED]
A point charge [tex]Q_1[/tex] is located in the centre of a spherical conducting shell with inner radius [tex]a[/tex] and outer radius [tex]b[/tex]. The shell has total charge [tex]Q_2[/tex]. Determine the electrostatic field [tex]\vec{E}[/tex] and the potential [tex]\phi[/tex] everywhere in space, and determine how much charge is on the inner and outer surfaces of the shell after electrostatic equilibrium has been reached.
Gauss law: [tex]\oint_S\vec{E}\cdot d\vec{a} =\frac{ Q_{encl}}{\epsilon_0}[/tex]
Area of a sphere: [tex]A=4\pi r^2[/tex]
Surface charge density (homogenous charge distribution): [tex]\sigma = Q/A[/tex]
Electric field from a point charge: [tex]\vec{E}(\vec{r})=\frac{1}{4\pi\epsilon_0}\frac{Q}{r^2}\hat{r}[/tex]
Electric field from a surface charge: [tex]\vec{E}(\vec{r})=\frac{1}{4\pi\epsilon_0}\int_S\frac{\sigma da}{r^2}\hat{r}[/tex]
I call the charges on the inner and outer surfaces [tex]Q_a[/tex] and [tex]Q_b[/tex] respectively. The electric field inside a conductor is always zero, so Gauss law on a surface [tex]a<r<b[/tex] gives
[tex]0=\oint_S\vec{E}\cdot d\vec{a} =\frac{ Q_1+Q_a}{\epsilon_0}[/tex]
[tex]\Rightarrow Q_a=-Q_1[/tex]
The total charge of the conductor:
[tex]Q_2=Q_a+Q_b=Q_b-Q_1[/tex]
[tex]\Rightarrow Q_b=Q_1+Q_2[/tex]
The total electric field could be calculated by taking the sum of the electric field from each charge.
[tex]\vec{E}_{tot}(\vec{r})=\vec{E}(\vec{r})_1+\vec{E}(\vec{r})_a+\vec{E}(\vec{r})_b[/tex]
E-field from the point charge:
[tex]\vec{E}_1(\vec{r})=\frac{1}{4\pi\epsilon_0}\frac{Q_1}{r}\hat{r}[/tex]
Introduce the surface charge density [tex]\sigma_{a,b}=Q_{a,b}/A_{sphere}[/tex]
[tex]\begin{align*}\vec{E}_a(\vec{r})=&\frac{1}{4\pi\epsilon_0}\int_S\frac{\sigma da}{r^2}\hat{r} \\<br /> &=\frac{1}{4\pi\epsilon_0}\int_0^r\frac{Q_a da}{4\pi a^2 r^2}\hat{r} \\<br /> &= \frac{Q_a}{16\pi^2\epsilon_0a^2}\int_S\frac{rdrd\theta}{r^2}\hat{r} \\<br /> & =\frac{Q_a}{8\pi\epsilon_0a^2}\int_0^r\frac{1}{r}\hat{r} \\<br /> & = \frac{Q_a}{8\pi\epsilon_0a^2}\left[ln|r|\right]_0^r<br /> \end{align*}[/tex]
which does not make sense. Similar problems arise for E-field from [tex]\sigma_b[/tex]. Can anyone help me out, please?
Thanks in advance.
Use the spherical symmetry of the problem: the magnitude of E depends only on r, and it is parallel with the radius at any point. As [tex]d\vec{a}[/tex] is normal to the surface of the sphere and so is [tex]\vec{E}[/tex]
[tex] \oint_S\vec{E} \cdot d\vec{a} =\oint_SEda[/tex]
where E is the magnitude of the electric field at distance r from the centre of the sphere, and it is the same at each point of the surface, therefore
[tex] \oint_S\vec{E} \cdot d\vec{a} =\oint_SEda<br /> = 4\pi r^2 E=\frac{ Q_{encl}}{\epsilon_0}[/tex]
You know well that the electric field is zero inside the conducting shell, you know that the enclosed charge is Q1 for r<a and Q1+Q2 for r>b...
ehild
Thank you! That was really helpful.
  • · Replies 17 ·
  • · Replies 18 ·
