Why does the temperature goes up following rainfall (then gradually cools down)?
  • Context: High School
  • Thread starter Thread starter srk999
    Temperature
The discussion centers on the phenomenon of temperature increase following rainfall, attributed to the ground releasing heat in the form of moisture. Participants agree that the heat trapped in moisture raises the temperature temporarily, after which it gradually cools down. Factors such as humidity levels and thermal equilibrium are highlighted as influencing temperature changes. Additionally, the impact of cold or warm fronts associated with rainfall is acknowledged, with the consensus that wet ground can lead to evaporation, further affecting temperature dynamics.
  • Understanding of thermal equilibrium and its effects on temperature perception
  • Knowledge of humidity and its role in weather patterns
  • Familiarity with meteorological concepts such as cold and warm fronts
  • Basic principles of heat transfer and moisture dynamics
  • Research the effects of humidity on temperature fluctuations
  • Explore the relationship between rainfall and thermal dynamics in soil
  • Study meteorological phenomena related to cold and warm fronts
  • Investigate the process of evaporation and its impact on local temperatures
Climate scientists, meteorologists, environmental researchers, and anyone interested in understanding the interactions between rainfall and temperature changes.
srk999
From my observation I saw that the temperature goes up immediately after rainfall. Then it gradually cools down. I don't really know why it happens, but I think it happens because the ground releases heat (upward) in the form of moisture as water touches the ground. It is the heat trapped in the moisture that raises the temperature for some time, after which it cools down.
Do you agree with me? Why do you think this happens? Why doesn't the ground release as much heat when it is not raining?
Science news on Phys.org
i'd assume it has a lot to do with humidity as you said, also keep in mind that when it is not raining your body is in thermal equilibrium with your surroundings, so as the temperature changes, you begin to feel the shift in equilibrium as heat or cold.
During heavy rainfall the temperature always goes down, because the water comes from above where it's colder. If the rain stops it will likely go up again. Of course rain often comes with cold or warm fronts that will change the temperature. If the ground is wet
and relative humidity is smaller than 100% water will evaporate and this will make it colder.
I don't think the rain will help the ground release heat in any way. If the ground is still warmer than the air after the rain, it can help the air to warm up again to some extent.
  • · Replies 32 ·
16K
  • · Replies 19 ·
  • · Replies 42 ·
12K
  • · Replies 20 ·
12K
