Second derivative=0; stable/unstable equilibrium?
  • Thread starter Thread starter saraaaahhhhhh
    Equilibrium
The discussion focuses on determining the stability of equilibrium points in classical dynamics when the second derivative of potential energy, [d2U/dx2]_0, equals zero. It is established that if the second derivative is positive, the equilibrium is stable, while a negative second derivative indicates instability. When the second derivative is zero, further analysis is required, often involving higher-order derivatives or Taylor expansions. The conclusion drawn from the potential's form, U = kx^n, indicates stability for even n and instability for odd n, which is a critical insight for understanding equilibrium behavior.
  • Understanding of classical dynamics principles
  • Familiarity with derivatives and their physical interpretations
  • Knowledge of Taylor series expansions
  • Concept of potential energy functions
  • Study the application of Taylor series in analyzing stability in classical mechanics
  • Explore the physical significance of higher-order derivatives in potential energy
  • Investigate examples of potential energy functions of the form U = kx^n
  • Learn about neutral equilibrium and its implications in dynamics
Students of classical mechanics, physics educators, and anyone interested in the mathematical analysis of equilibrium stability in dynamical systems.
saraaaahhhhhh
Describe how to determine whether an equilibrium is stable or unstable when [d2U/dx2]_0 = 0
From Classical Dynamics - Ch 2 #45 - Marion Thornton
2. Homework Equations AND 3. The Attempt at a Solution
When second derivative positive, equilibrium is stable. When second derivative negative, equilibrium unstable.
When second derivative is 0, you have to do another test. I was under the impression that you could find a third derivative, fourth derivative, until you get a positive/negative value for x=0 and use the results to get stability, with the same rule as above? And if second and subsequent derivatives are 0, it's a neutral equilibrium.
The main reason I'm confused is the book had a weird solution that didn't make sense to me. They expanded the potential about the equilibrium point (how? why?), found the first derivative, and said that it's stable when n is even and unstable when n is odd. But that doesn't make sense to me. How could they make a conclusion like that if they don't know what U is?
Maybe I'm misunderstanding the question's notation - I understood it to mean "second derivative at x=0 is 0."
What is n? Is your potential of the form U = kxn (n > 0)? If so, sketch the potential for even and odd values of n and see for yourself what happens at x = 0.
Ermmm...what the heck is a "neutral equilibrium"?:confused:
I'm guessing that the expansion is a Taylor expansion...you know how to do those right? What is the derivative of potential equal to physically? What should that quantity be near a stable/unstable equilibrium point?
